Question about Kirby Generation 3 Bagged Upright Vacuum
How to hook up the shampooer to the kirby vacuum i need a pictures
Help
  • 625 Answers
The following link will take you to your machine's schematics http://vacuumsuperstore.com/Generation3.html
Posted on Sep 22, 2007
  • 357 Answers
Here is a link to my online guide. I also have Kirby manuals available if needed. It comes in quite handy in these situations and is very affordable. :0)
Marci
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Posted on Oct 23, 2007
b0sslady2001
  • 357 Answers
SOURCE: shampooer instructions
Here is a step-by-step guide to help you out!!
Hope this helps,
Marci
Posted on Jun 28, 2009
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
  • 7 Answers
SOURCE: Kirby G4 Vacuum/Shampooer
i find the kirby carpet washer is rubbish coz it leaves all the dirty water in your carpet and it goes smelly!
Posted on Jul 11, 2009
b0sslady2001
  • 357 Answers
SOURCE: I am trying to hook up the shampooer to my moms
Here's a free online guide...
Please be sure to rate it if it's helpful. :0)
Marci
Posted on Oct 30, 2009
  • 694 Answers
SOURCE: how can i get a
I haven't been able to locate Kirby manuals, but they do have good instruction videos for hooking up the shampooer, changing the belt, etc. Just click on the video you need.
http://www.kirby.com/Portals/0/videos.html
Posted on Oct 08, 2010
How can i get a manuel . I don't know how to hook up the parts for the shampooer to clean carpet . Need ASAP.Kirby vacuum model #293001 serial G.
Oct 08, 2010 | Vacuums
How to put bag assembly on kirby g4 shampooer
You have to disassemble shampooer before putting vacuum back together, once you do that then look at this video on our site:
http://www.goodvac.com/
Good luck,
Rocky
Dec 18, 2009 | Kirby G4 Bagged Upright Vacuum
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby g2000 shampooer
Your belt is not properly connected. Here is the instructions to properly install the belt on the main power nozzle. It works exactly the same way as the shampooer head, so this should be of help...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Here is the instruction guide for the shampooer also. Hope this helps...
Marci
Jun 10, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby shampooer
here are instructions with pictures of how to put the kirby shampooer together...
http://www.greatvacs.com/shampoo.shtml
hope this helps!!!
Mar 28, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby Shampooer
this site has instructions with pictures
Hope this helps!!
Mar 25, 2008 | Kirby Heritage II Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
226 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
