APC Smart-UPS SC 1500VA UPS System Logo
A
Anonymous Posted on Oct 02, 2013
Smart-UPS 1500 XLM 5 led blink bypass led light
5 Related Answers
Anonymous
  • 37 Answers
  • Posted on Mar 24, 2009
SOURCE: I have just replaced the battery of my 1500 smart
hmmm juz turn off and on the ups also the power source if it not workin you hav to check your setting which u install the software?
Anonymous
  • 55 Answers
  • Posted on May 09, 2009
SOURCE: Smart UPS 1500 - battery level green lights blink on and off
You need to run recalibration on the unit.  The supplied PowerChute software & cable will allow you to do this if you hook the UPS up to a PC (I know it works with the serial cable, not sure about USB).  If you only have a MAC then I cannot offer a solution other than to buy the standalone PowerView device from APC.  It will cost a bit more than a battery, but may save you from buying needless batteries in the future.  I finally broke down an bought one, but note that I was still having the problem after the 1st recalibration.  By trial and error (and maybe a vague memory) I put my MAC in sleep mode, that dropped the load to stop the lights from flashing.  Then I recalibrated with a 22% load and now it finally seems better (lights no longer flashing).  This was with a Smart-UPS 1000.
Let me know if that helps.
Anonymous
  • 2567 Answers
  • Posted on Jul 19, 2009
SOURCE: bypass LED on the ups is on
This an excerpt from the UPS's manual:
The Bypass LED illuminates indicating that the UPS is in bypass mode. Utility power is sent directly to connected equipment during bypass mode operation. Bypass mode operation is the result of an internal UPS fault, an overload condition, or a user initiated command through an accessory. Battery operation is not available when the UPS is in bypass mode.
Jesrey Paco-in
  • 91 Answers
  • Posted on Aug 14, 2009
SOURCE: APC smart ups 1000va
Here we go again.. i encouter a lot of this problem. just change the whole front panel board and everything will work fine.
Anonymous
  • 25 Answers
  • Posted on Mar 09, 2010
SOURCE: APC smart UPS
Check mosfet.
6 LEDs blinking in APC 1500 smart ups
what model is it , rear sticker, shows moldel.
APC makes vast 1500watt ups, not told.
first replace of first test the batteries, 9 of 10 times bingo EOL batteries. RIP
smt1500
bx1500
SAU1500? ahh has 6 led faults and the manual covers that.
blinks sequentially means AC power lost to the building, wall or breaker to this service panel tripped, loss of POWER
page 11 in your manual read it. it tells both off those
ALL LEDS ARE LIT AND THE UPS EMITS A CONSTANT BEEPING
Internal UPS fault.Do not attempt to use the UPS. Turn the UPS off and have it serviced imme-
diately.
and
FRONT PANEL LEDS FLASH SEQUENTIALLY
The UPS has been shut down
remotely through software or
an optional accessory card.
None. The UPS will restart automatically when utility power returns.
Apc smart ups 2200 all led flashing 3 orange 2 red 1green,what is that? and How to Fix It?
this problem is caused control board with that. the solution is replacement.
2answers
Internal problem galaxy 3000 ups
The question is not clear... which of the LED`s are lit?? green, yellow, red.is there a message on the screen??
2helpful
2answers
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
2answers
All led blink
hi, if the leds blinking are for batteries (the ones above the battery symbol) then its not that the machine is not faulty. it needs some calibration constants. contact your local apc service engineer centre. this happens especially after battery change.
Bypass LED on the ups is on
3helpful
2answers
I have just replaced the battery of my 1500 smart UPS and all the LED are blinking. What should I do to make it functional as before?
After powering on, all non-graph LEDs keep blinking
That meens that UPS dont have battery power for minimum time (2min). Unplug some devices so UPS load need to drop below 25% and lets UPS recharge battery
Top APC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
