Question about Bose Lifestyle 30 System
Cd stuck I put a cd in upside down and it won't eject what can I do??? I have the single bose wave music system
  • patrickschey Dec 30, 2007
    my 6 disk magazine will not eject, on mybose lifestyle 20 system i tired powering off and hitting the eject button at 2 second intervals but it only sounds like its trying to eject a disk and then it sounds like its trying to eject the magazine but nothing happens
  • Anonymous Feb 18, 2008
    Cannot eject, keeps shutting down
  • 752 Answers
Unplug the unit and as you plug it back in start pressing the eject button in one second intervals as it powers up. This should command it to eject before it tries to read the disc.
Posted on Sep 21, 2007
SOURCE:
I cant insert a CD into my Bose Wave Music System. I think there is a CD stuck there. How do I get it out?
It is very difficult to remove a stuck disc and may require removal of the cabinet to get inside the works. Best to take it to a qualified service shop where they can do it for you.
Oct 09, 2014 | Bose & Wave& Music System
A CD is stuck in my bose system How do I get it out?
From an other web site
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
What's your problem?Bose wave system cd doesnot eject
Contact the nearest authorised service center for Bose. CD loading mechanism has been struck. You have to open it. It is a skilled work.
Jun 09, 2012 | Bose & Wave& Music System
Hello I have a Bose Wave music system-single cd capacity and a cd is stuck in it-I kept pressing "eject" as it was saying "disc error" it now says "no disc" even though the cd...
The Bose Wave System is top of the line and deserves a specialist, the Bose service department does all the repairs on their own products and carry the parts to implement such repairs. They do not authorize any other repair facilities to work on their items. I suggest you get in touch with them to assess your Bose Wave Music System.
Mar 14, 2011 | Bose Audio Players & Recorders
Think kids put cd in upside down can't eject and says disc error(bose wave one cd player) How can I get it out?
open up paper clip and poke gently in to into the very small located on frontoff c/dvd this will manualy open drive,to remove ****.
Mar 04, 2010 | Bose Wave Radio
Bose Wave System CD does not eject
Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
Hope it may helps;
Jun 12, 2009 | Bose Wave Music System CD Shelf System
My bose cd player won't take a cd now and play it but the radio works fine. There doesn't seems to be any disc inside. The display says no disc.
It looks like this is a Wave Music System. (Front, slot-loading CD drive? About 4 inches tall?)You could try a basic reset. Just unplug it from power for about 30-40 seconds. When you plug it back in, it should try to 'force-eject' anything that could be stuck inside. Otherwise, try another CD after the reset to see if it pulls it in and it plays. If that doesn't work, you could try flipping it upside down and pressing eject. (a roller could be stuck on something)
Let me know if this helps.
Jun 10, 2009 | Bose Cinemate Digital Home Theater System...
A disc is in the Bose Wave system and will not play or eject
Unplug the system. Turn the entire unit upside down. The CDs will eject. After I tried this (found it online somewhere), it worked fine for about 2 months. Now it suddenly turns on by itself and ejects CDs (creepy). But at least the original problem was solved.
Apr 05, 2009 | Bose Wave Music System CD Shelf System
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Dec 22, 2008 | Bose & Wave& Music System
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Bose Lifestyle 30 System Logo
    396 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Steve Allison
    Steve Allison
    Ekse
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
