Question about Sony Playstation 3 (PS3) Console
Ps3 blu-ray remote control
I cannot get the remote to work the ps3 & the remote are all new, the hand playiny controls work.please if you can help . thank you
Re: ps3 blu-ray remote control
If you have not registered your bd remote with the system you need to do so. Go into the Settings menu, remote settings, and register bd remote.
Posted on Oct 22, 2008
Make sure you are pressing the enter button in the middle of the direction circle and not the select button beside the start button as this was my problem
Posted on Dec 07, 2007
0 characters
3 Points
Ps3 skips while playing dvd
Get a dvd cleaner cd from walmart or target that is made for blu ray's and that will help you out a lot, if you have a console like mine where the top opens and you can access the dvd and see the eyes if the laser, take a q-tip with some isoproyl alcohol and clean both eyes off, but make sure the q-tip is not overly soaked since you don't want the extra liquid dripping into the console!
Oct 05, 2014 | Sony Playstation 3 (PS3) Console
If you have any experience working on things like this, you should be able to swap your blu-ray drive out with another one. They can easily be purchased off of ebay, and all you have to do is remove the drive from the PS3, detach the controller board (the board on the bottom of your drive), and attach it to the new blu-ray drive, and put it back in the PS3. The controller board on the bottom of your blu-ray drive "pairs" it to your system. Hope this helps!
Feb 26, 2011 | Sony Video Game Consoles
Please explane how to hook my playstation 3 blue ray remote up to my playstation 3
1Insert the two AA batteries into back of the DVD/BD remote.
  • 2Power on your PlayStation 3 system manually. You can accomplish this by pressing the "PS" button in the middle of your wireless controller, or on the front of your PlayStation 3.
  • 3Navigate to "Settings" on the PS3 home menu, referred to as the XMB.
  • 4Scroll down the list of settings and select "Accessory Settings" by pressing "X" on your PS3 wireless controller.
  • 5Select "Register BD Remote Control" by pressing the "X" on your PS3 controller.
  • 6Follow the on-screen instructions that appear for registering your BD/DVD remote control. Once the remote is paired, you can control various multimedia applications on your system.
  • Feb 10, 2011 | Sony Blu-ray Remote for PlayStation 3
    Can't pair up my blu-ray remote with the PS3.
    I had same trouble in the beginning.
    I have 80G PS3 and tried pairing and also registering.
    I solved it by taking out the batteries then going to the menu where it says Register Blu Ray remote (System 2.40 version) then put the batteries back in and you do as the instruction says => Press Start and Enter button at the same time for 10 seconds ... it will say it registered.
    I just did it.
    Dec 29, 2008 | Sony Blu-ray Remote for PlayStation 3
    Playing blu-ray movies
    call sony for help your unit my be bad
    Dec 12, 2008 | Sony Playstation 3 (PS3) Console
    Connecting the remote to PS3
    alll easy i in fact re paired mine last night. on the ps3, with a controller, go into settings, the accesory settings, then bd remote then follow the prompt. so easy a 3 year old could work it
    Dec 09, 2008 | Sony Blu-ray Remote for PlayStation 3
    Ps3 remote
    which remote the controller or the remote to control the bluray and stuff. If its the controller just plug it to the ps3 with the usb cable then press the ps button. If it's the remote for the blu ray. I'm pretty sure you just have to go the the "Accessory Settings" and find the option to pair devices. Make sure the remote is in the mode where it searchs, check for that in the booklet, and there may even be a code you have to put in the ps3 (possibly '0000') or whatever it may say in the booklet.
    Oct 10, 2008 | Sony Playstation 3 (PS3) Console
    Ps3 blu-ray remote control instructions
    you use the ps button on the remote (if you have the correct remote for your ps3) the ps button is clearly marked and is found just above the SELECT and START buttons
    Sep 21, 2008 | Sony Playstation 3 (PS3) Console
    PS 3 Blu Ray drive not working
    hi im silver surfer, i work in a ps3 repair center and have a little bad new's for you all that own ps3 can NOT just take out a bd drive "blue ray drive" and put it in another console or put a new bd drive in a console. IT WONT WORK... the drive has to be programed to your ps3.and to do this your ps3 has to be put into factory mode to program it,this equipment you need to do this is very hard to come by,
    May 31, 2008 | Sony Playstation 3 (PS3) Console
    PS3 Codes for Universal Remote Control
    usually universal remote controls DO NOT (and most remtoes cannot communicate with the sony ps3) include codes for this...most remotes are imposible to do this.
    Feb 24, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    1,845 people viewed this question
    Top Sony Video Game Consoles Experts
    Troy Gorman
    Troy Gorman
    Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
