Question about D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server
Printers are not recognized as online by printserver
I am using the D-link DIR-635 router and the DPR-1260 printserver in a wireless 11g network (DHCP), Windows XP SP2. Installation of the printserver went fine, installation (by Wizard) of a Canon LBP2900 and iP4300 went well also. Both printers show up in the "Printers and Faxes" folders. Problem is that the printserver does not recognize the online status of the printers and keeps stating "offline" in the utility. So does Windows. Trying to print generates an error message "Wrong port. The port the printer is connected to can not be used. Check the port". The correct printer drivers are installed on the computer, I tried to share the printers but it did not help. Since the printers showed up in the menu I have not installed them manually. What did I miss?
  • Impala66 Sep 23, 2007
    I think that the problems lies in the configuration of the port or the way the port is handled by the computer/router/printserver. Here are the port settings (from the Windows Printers & Faxes menu):
    Port:
    d-link_15a365_9101 (this is the USB-port the printer is connected to)
    Standard TCP/IP Port, Raw TCP/IP, #9101, SNMP activated, "Public", index 1
    Printer:
    Canon LBP2900 on DPR1260(dlink-15a365 USB Port2)---this seems to OK
    I had the printer switched off when I started the PC, the Windows Printers menu stated "ready" for the printer (???). When I switched the printer on, the status changed to "offline" ???!???
  • Impala66 Sep 24, 2007
    I have seen at least two similar issues at FixYa (with HP printers).
    Master:
    Sergeant:
  • 461 Answers
Have you check which port your PC trying to register your printer to?
Posted on Sep 23, 2007
SOURCE:
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Is the d-link printerserver dpr 1260 working with Vista 32 bits
Connect the printserver wirh the Wiredless internetrouter and disable the firewall Start internetexplorer and type dlink-xxxxx the last 6 digits of yor mac adres from the d-link printserver. you sould then have a connection with the printserver.
Succes
Dec 26, 2009 | D-Link Computers & Internet
Dir-655 works with XP and Mac which can connect
Go to 192.168.0.1 and login. Then go for the 'Setup' tab on the top and look for the 'Wireless Settings' tab on the right.
You can now automaticly setup your WLAN connection and afterwards you can go to the 'Manual Wireless Network Setup'. Over there you can change the 802.11 mode.
  • 802.11b only
  • 802.11g only
  • 802.11n only
  • Mixed 802.11g and 802.11b
  • Mixed 802.11ng and 802.11g
  • Mixed 802.11n, 802.11g and 802.11b
Go for the last one that uses n,g and b and you will be sure your computer can connect :)
Dec 14, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Windows 7 compatibility forthe DPR 1260
My DPR-1260 arrived yesterday and I set it up easily in minutes on both Windows 7 (32-bit Pro) and XP SP3 with 3 printers attached. So far I have only tried wired connection. Wi-fi may be more problematical.
Printers are Brother HL-2040, HL-2140 and Samsung CLP-300. Could not get it to recognize my Canon Lide 25 scanner
Oct 30, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Hi!!! How do I set up wireless printing? I have an HP1022 printer...
You should have your DSR 1260 connected via cable to your router. Open a browser. Go to http://dlink-xxxxx (xxxx=last 6 digits of your 1260's MAC address) or http://192.168.0.10. The DSR 1260 web config screen will open. Click on the Setup tab (top row). Then click on Wireless Setting on the left hand column menu. Select settings based on your router's setting, Typically: Wireless Setting: On; Network Name: choose from drop down, if not there, type your router name in; Wireless Mode: Infrastructure; SuperG Mode: same as your router; Security: same as your router. Then Save.
Remove the cable connection of your 1260 and your router. Then go to Status in the web config. Click on Wireless. It should now show your router details. That's it.
Jan 24, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Can't connect a Dlink 1260 Print server through my Linksys wireless G router
A couple of things to check for:
  • If the wireless network is encrypted on your router verify that you have the right encryption key programmed on the print server
  • You are connecting to the corret router (Verify the SSID of the network - SSID being the networks name)
  • Make sure you are in an acceptable range , not 500 feet away from the router
  • Verify that the print server has a connection to the printers connected to it
  • Try rebooting all of the equipment (router , server, printers)
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Sep 28, 2008 | D-Link DPR1260 Rangebooster G...
Problem with the wireless d link DIR- 635
I'd try doing a power cycle. Power off all the equipment. Plug in the Modem untill the online light is solid, then plug in the router, then i'd turn on your laptop.
Ensure that your connecting to the right network. Under the network settings the SSID is your Network name. Make sure it's not a generic name.
If you have a cable provider, you can just bring it to Geek Squad. They'll setup the router and setup all the security features in the store within about 10-15minutes.
Jun 19, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
DPR-1260, HP All in one 2210, and IE7
Make sure your printer is on the compatibility list provided by D-Link. The list is in the following link: http://support.dlink.com/faq/view.asp?prod_id=2316&question=DPR-1260
Aug 20, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Open Questions:
See all D-Link DPR1260 Rangebooster G Multifunction Print Questions
D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server Logo
945 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
