Question about Corona Hedge Shear 10 1/2" Blade Aluminum Handle Hedge Shear Long Blade Aluminum Handle
Lost blade hinge pin
I have lost the blade hinge pin on my Corona, aluminum handle, compound action hedge shear, # WM 1501. Where can I get a replacement?
2 Suggested Answers
SOURCE: Corona professional long-handled hedge shear
try tightening the nut and bolt that hold the shears
Posted on Dec 01, 2008
Stihl HS45 hedge trimmer runs fine, blades move well, does not appear to cut hedge - what could be the problem ?
Dull blades! Lol, or they're not meeting eachother on each reciprocating stroke so there is no shearing action, much like a pair of scissors. Check to see if the blade bolts are too loose or is the blades are warped or if the cutting edges are simply too dull
Sep 24, 2013 | American Gardener Rh25 18" Readyhedger...
I bellieve I have sheared a pin or bolt. The trimmer runs fine but the teeth do not move. Any suggestions. Is there a operators manuel online?
Had the same problem with my Stihk hs 81 R hedge trimmers. Ive stripped it down and found that the clutch drum had sheared. Hope this helps.
Apr 28, 2012 | Black & Decker 22 In Dual Action Hedge...
Blades dont move
If the motor is turning and the blades are not moving it is likely that you have sheared the pin on the gear.
Aug 23, 2011 | kawasaki Kht600d Gas Hedge Clipper Trimmer
Hedge trimmer blades dont move although the electric is still getting to the motor you can still here the motor turning but no movement from the blades
Likely the pin in the gear has sheared. You will need to replace it. It is designed to shear to protect the motor.
Aug 23, 2011 | Garden
How do you release the saw blade from the closed position on a Hitachi C10FCH 10" Compound Saw?
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Feb 23, 2011 | Hitachi 10" Compound Miter Saw (with Laser...
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
Blades on hedge trimmer stuck or not moving, engine runs fine.. what is the problem?? (echo trimmer)
There is a pin in the gear that helps the blade move when the engine is running. That pin may be sheared off and may require a new gear.
Dec 05, 2009 | Garden
Nov 16, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Corona Hedge Shear 10 1/2" Blade Aluminum Handle Hedge Shear Long Blade Aluminum Handle Logo
61 people viewed this question
Top Corona Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Corona Garden Expert? Answer questions, earn points and help others
