Question about NetGear WGR614 Wireless Router
I need to modify the settings on my router.How do I do that?
  • 728 Answers
Hello maskman01,
The first thing you do is to login to the router. You can do that by opening up your browser and typing in 192.168.1.1. And the default user name is admin, and the default password is "password"
Once inside you'll find all the options to modify the setting.
Good Luck and don't forget to leave a rating.
Thanks Mark
Posted on Apr 21, 2009
  • 560 Answers
Follow this help guide to access Netgear router login and setting page
http://comprehensive-support.blogspot.in/2011/04/how-to-access-netgear-router-login.html
Posted on Oct 12, 2012
Lost password and i cant use my ipohne with router.
Modify the router's settings.
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing www.fixya.com and kindly rate this post.
Jan 03, 2012 | Linksys WRT110 Wireless Router
Can not use router
Modify the settings of your Netgear first:
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.0.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
Jan 03, 2012 | NetGear N300 Wireless Router
Can not acess wifi
Try connecting your laptop to your router with an ethernet cable and verify that it can connect that way. Once you verify that it can connect using an ethernet cable try and login to your router and modify the wireless settings. If you give me the routers model I can lookup a guide on how to modify your wireless settings.
Mar 01, 2011 | Computers & Internet
What Do i do when I exceed the limit password reset, to access my account?
You can make a full reset to your router. Stick a pin in the reset hole for about 30 seconds and your router will be set on default settings Of course you will loose all your settings, but you will be able to access your router and modify what settings you want.
If you need further assistance, or have further questions, just leave a comment. Thank you or using FixYa. Cheers
Jan 20, 2011 | Computers & Internet
Modify settings on router
To change the settings of the router you will need to access the router set up interface.
When you change the settings on the router make sure that your computer will be connected to the router with the cable.
I hope the following link may guide to open the router set up.
Click Here for step by step solution
Nov 01, 2009 | Linksys WRT160N Wireless Router
Unable to connect to internet by my zonet zsr1134we router. when you view available network it shows security enabled network but won't connect.
Do you know the network key of the router? If you do and still you won't be able to connect, modify the router and try changing the network key.
If the security that's set to the router is WPA-PSK, try changing it to WEP and create a new network key. If same problem occurs, try changing the channel.
Another option is to reset the router to it's factory default and reconfigure the router.
Last option, perform a firmware upgrade and this should resolves the problem.
NOTE: Make sure to try different laptops before modifying the router.
Have a great day!
Oct 14, 2009 | Zonet ZSR1134WE Wireless Router
Need passphrase from D-Link router DI-524
1. if the default login never been modified b4, u can hook a network cable to the router, type "192.168.0.1" to enter the router config. Once inside, u can edit the password or disable it.
*U may prompt for username (admin) and passsword(empty).
2. If the default login has been modified and u r not able to enter the router config, u can just reset the router by inserting a pin to the small hole to get back the factory default settings. Then u can perform above step again to reconfigure your wireless router.
Mar 13, 2009 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
How can i setup my dlink 514 router?
Connect one of your computer to LAN port, access the configuration page of the router (IP 192.168.0.1) for the connection type choose dynamic IP address, clone the MAC address then apply the settings, Check the IP address under status (WAN section if you have the IP address it means that your connected)
Mar 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
About opening nat
Router is designed for NAT connectivity which is you don't need to configure it out.
Please rate me SOLVED
Nov 22, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
NetGear WGR614 Wireless Router Logo
315 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
