Question about Fisher and Paykel GWL11 Top Load Washer
F & P GW712 - bowl spins, but won't fill.
I moved house the other day and now the washing machine (Fisher & Paykel GW712) won't fill. Water supply appears to be fine. Powers up OK and allows selection of wash preferences, however, bowl just spins and makes no attempt to fill on either hot or cold. Tried advancing the wash cycle to rinse, but again, does not fill. Was thinking the bowl might be out of balance, but not sure.
  • 4 more comments
  • Anonymous Dec 04, 2007
    I have the same problem.. It wont fill with water..
  • wee willie Dec 07, 2007
    bowel will spin no water will come in- the problem is between the hose and the bowel.
  • succer Mar 13, 2008
    Same problem here. Machine is only 2 years old and have a couple problems. 1) can only wash 1/2 loads or lights blink and machine beeps. 2) since last unbalanced load was corected, machine will only fill about 2 cups of water in and then start and stop agitation without any more water.
  • buretachi Jul 30, 2008
    I have a Fisher and Paykel GWL11-US which has been leaking a wee bit under the machine, then developed a bit of an internal drip at the end of a cycle, and now this morning won't fill at all. The bowl spins, but no water. I've checked the water supply and cleaned the filter at the tap; still nothing. I can't figure out how to remove the filter at the machine.
  • Anonymous Mar 24, 2014
    fisher & paykel washing machine GW512 will not stop filling cold water
  • Anonymous Mar 29, 2014
    Replaced wiring harness on the Fisher and Paykel GW712 washing machine and now first and seventh light comes on just after the start of fill. Also have noticed the same lights come on immediately when washing machine is tilted back.
Check the hieght of your outlet hose, the bowel will run out of the hose until they level out,hook your hose by a hanger to the back of the machine
Posted on Mar 27, 2012
    Problem Solver:
  • 13 Answers
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Posted on May 04, 2008
Can you replace a GW712 Drive Motor ?
i believe that unit encases the clutch assembly and can be replaced but its a lil work and some force needed
Feb 07, 2015 | Fisher and Paykel Washing Machines
GW712 - cold wash selected but water runs warm. If hot water supply turned off, machine stops?
The cold water temp has been adjusted to a warmer temp,
Move the led back to the first led light with advance button.
Jul 01, 2012 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
Fisher & Paykel GW712 hot water fills fine - cold water just trickles. Was working fine until yesterday
Turn that spigot off, then unscrew the hose from the machine and inspect the screen that is there (on most machines, some have internal screens/filters) If that screen is clogged, you can clean it or get a new one, if it is damaged. Place the hose inside the washer, or someplace you know the water will drain away, turn on the spigot to make sure you have a flow from the spigot to the end of the hose. Reattach and charge the hose. I believe this will be the answer.
Hope it is helpful. Please rate and comment, Thank You
Sep 01, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Gw712 washing cold water supply through solonoid
Remove the cold water fill line at the back of washer and put it
over into the tub and turn it on if you have plenty of water
then you need the valve that it screws onto.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Sep 06, 2010 | Fisher and Paykel Washing Machines
GW712 Fisher & Paykel Washer. Cold water will not fill the machine only a trickle. Taps, water temprature and hose working correctly.
Jan 11, 2010 | Washing Machines
Water not pumping out F&P GW712
If you can hear your pump running then your drain hose might be clogged, if not it is probably the pump and will need more in depth troubleshooting.
Oct 25, 2009 | Fisher Washing Machines
Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Sep 14, 2009 | Fisher Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
486 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
