Question about Estate TAWB600JQ Top Load Washer
Wash Machine Drainage problem
I have a Whirlpool Estate Washing Machine that someone just gave me. I have it hooked up right and everything is working great except --- it seems to be draining to fast and the drain hose is hooked up correctly and then the pipe is filling up fast and overflowing. I have tried cleaning out the drain with drain chemicals and have also used equipment to clean out the pipes. Is there anyway to slow down the water flow or to put a smaller hose on it for the pipe will not fill out so fast? I live in an older home. Thanks!
  • 209 Answers
I am a recently retired appliance engineer of 20 years, slowing down the flow of water from any electrical washing appliances can be dangerous and will cause extensive damage to the appliance in question, at the very least it will stop half way through the cycle every time the only way to remedy this is to rectify the drain, or at least sort out another waste water outlet sorry
Posted on Sep 21, 2007
How to fix a whirpool washing machine won't drain or spin cycle
First check to see if the drainage system at the bottom of the machine is not clogged. Depending on the model, the drainage service plug (a big screw on cap) should be accessible when the bottom panel is removed. Remove the cap and clean out everything that is blocking the screen. Put it back on after cleaning and see how it goes.
Oct 17, 2014 | Whirlpool Washing Machines
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Where do I find the modle number
You should be able to find it either printed somewhere on the front (such as Whirlpool Combi Heaty Wash) or on the sticker with the serial number on the back of the unit
Oct 15, 2014 | Estate Washing Machines
My estate washing machine will not spin out, all of the other cycles work correctly.
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
How can I tell the age of my washing machine?
I would have to say from looking up your owners manual and the copy right date it is about a 2000 model.
Jan 04, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer smells after load
First thing to try is to get affresh washer tablets. They are a new product from whirlpool designed for front loaders to keep the smell out. They also work great for top loading machines. They are about ten dollars a pack. Read the instructions and run the washer through its cycle and the smell get better. The longer you use it, the smell should go away.
Nov 17, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate TAWB600JQ Top Load Washer Logo
191 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
