Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Need to know how to reset ink cartridges
Without spending alot of money on new ones. If there is way to do that myself without any special equipment
  • 385 Answers
    Problem Solver:
  • 18 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
aqq-8
Posted on Sep 03, 2009
  • 728 Answers
Hello annettefoste,
This is part 1 of 2
Replacing an Ink Cartridge
The need to know how to reset ink cartridges - fonth.gif Ink light on the CX1500 lets you know when it is time to obtain a replacement ink cartridge and when it is time to replace an empty cartridge.
Follow these guidelines when checking the fonth.gif Ink light fonth.gneed to know how to reset ink cartridges - fontf.gif= Ink light
Action
Obtain a replacement black ink cartridge (T038) or color ink cartridge (T039)
need fonto.gif = on, fontf.gif = flashing
To replace an ink cartrineed to know how to reset ink cartridges - r_1.gifng the fonth.gif Ink Maintenance button, follow the steps below.
Note: need to know how to reset ink cartridges - r_2.gifr_space.gif The illustrations shoneed to know how to reset ink cartridges - r_space.gifnt of the black ink cartridge.
need to know how to reset ink cartridges - r_caut.gifr_1.need to know how to reset ink cartridges - r_space.gif Make sure that the CX1500 ineed to know how to reset ink cartridges - r_space.gifreen fontp.gif Power light should be on, buneed to know how to reset ink cartridges - r_3.giflashing. need Make sure that the document cover is closed,need to know how to reset ink cartridges - fonth.gif open the scanner unit. r_space.gif r_caut.gifCaution: r_space.gif r_space.gif When the ink is empty:
The fonth.gif Ink light is ON.need to know how to reset ink cartridges - fonth.gife fonth.gif Ink Maintenance button and continue with the next step. When need to know how to reset ink cartridges - aca8627.giflow:
The fonth.gif Inneed to know how to reset ink cartridges - r_space.gifce button for three seconds, and continue with the next step. The print head moves to the black or color ink cartridge replacement position, the green fontp.gif Power light begins to flash, and need to know how to reset ink cartridges - r_space.gifc="http://i.fixya.net/uploads/images/fneed to know how to reset ink cartridges - r_space.giflt="fonth.gif" class="h_mi" /> Ink light flashes or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the need to know how to reset ink cartridges - fdd5005.gifidge, press the fonth.gif Ink Maintenance button again to move the print head to the color cartridge replacement position.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif
  • Do not move the print head by hand, as this may damage the CX1500. Always press the fonth.gif Ink Maintenance button to move the print head.
  • When replacing ink cartridges, be careful not to touch the cartridge sensor shown below
Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder.
Posted on Apr 21, 2009
  • Mark Taylor
    Mark Taylor Apr 21, 2009
    This is part 2, now is going to a part 3 and possible 4, they don't give me much room on added comments.
    Note:
    The illustration shows color ink cartridge replacement. To replace the black ink cartridge, lift up only the smaller clamp on the left.
    Warning:
    If ink gets on your hands, wash them thoroughly with soap and water. If ink gets in your eyes, flush them immediately with water. If discomfort or vision problems remain after a thorough flushing, see a doctor immediately.
    Lift the old cartridge out and dispose of it properly. Do not take the used cartridge apart or try to refill it.
    Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape from the cartridge. Do not touch the green IC chip on the side of the cartridge.
    Caution:
    • You must remove the yellow tape from the cartridge before installing it; otherwise, the cartridge will become unusable and you will be unable to print.
    • If you have installed an ink cartridge without removing the yellow tape, you must remove the cartridge and install a new cartridge. Prepare the new cartridge by removing the yellow tape, and then install the cartridge in the printer.
    • Do not remove the blue tape from the top of the cartridge; otherwise, the print head may become clogged and be unable to print.
    • Do not remove the tape from the bottom of the cartridge; otherwise, the cartridge may become unusable.
    • Do not touch the green IC chip on the side of the cartridge; otherwise, normal operation and printing may not be possible
    End of Part 2
  • Mark Taylor
    If an ink cartridge is temporarily removed from the printer, protect its ink supply port from dirt and dust. Store the ink cartridge in the same environment as the CX1500. When storing the cartridge, be sure to position it with the label identifying the cartridge color facing up, as shown in the illustration above. The valve in the ink supply port is designed to contain any excess ink that may be released. However, careful handling is recommended. Do not touch the ink supply port of the ink cartridge or its surrounding area.
    • Be sure to always install an ink cartridge in the CX1500 immediately after removing an old ink cartridge. Failure to promptly install the ink cartridge may cause the print head to dry out and render it unable to function properly.
    Insert the ink cartridge in the ink cartridge holder, then close the ink cartridge cover. Don't try to force the cover. Make sure the cartridge is oriented as shown in the illustration below.
    The cartridge cover should click into place. If you are replacing both cartridges, press the Ink Maintenance button to switch to the color ink cartridge replacement position, and replace the cartridge as explained above.
    Caution:
    After you remove an ink cartridge, install a new one immediately. If no cartridge is installed, the print head may dry out and become unable to print.
    Note:
    The illustration shows color ink cartridge replacement. To replace the black ink cartridge, replace only the cartridge held by the smaller cartridge holder on the left.
    Close the scanner unit.
    Press the Ink Maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When ink charging is done, the printer returns the print head to its home position, the green Power light stops flashing and remains on, and the Ink light goes out.
    Caution:
    The Power light continues to flash while the CX1500 is charging ink. Never turn off the CX1500 while this light is flashing. Doing so can result in incomplete charging, which wastes ink.
    Conserving black ink when the cartridge is low
    The dialog box below appears when black ink becomes low and the following requirements are met:
    • Plain Paper is selected as the paper type on the Main menu.
    • There is more color ink than black ink.
    • The black ink cartridge is not empty.
    • The color ink cartridge is not low.
    The dialog box gives you the option either to continue using black ink normally or conserve black ink by using a mixture of color inks to create black
    By clicking the Yes button, you can use a mixture of color inks to create black when you print. Ink from the black ink cartridge is not used. In some cases, the black created by combining inks may differ slightly from that of the black ink cartridge. The dialog box appears the next time you print a job that uses black ink and again gives you the option to conserve black ink.
    By clicking the No button, you can continue using the remaining black ink for the job you are printing. The dialog box appears the next time you print a job that uses black ink and again gives you the option to conserve black ink.
    By clicking the Disable this feature button, you can continue using black ink normally. The dialog box does not appear again for the remaining life of the black ink cartridge. In this case, black ink is used normally until it runs out completely.
    That's it.
    It seems long but it's really not, it's just step by step
    Good Luck, and don't forget to leave a rating based on my Solution.
    Thanks, Mark
Can fuel sending connection be accessed thru trunk on 1997 buick lesabre custom
On some vehicles the FUEL PUMP can be accessed from under the rear seat without lower the gas tank. It would help to have more information about what your dealing with. I had trouble with my 1999 buick century, it wouldnt start. it ended up being a fuel delivery issue the shop i took the car to said i need a new fuel pump and sending lines, however i couldnt rationalize spending the money they were asking. I ended up fixing the fuel pump myself without spending any money. I got my infiormation from http://autoabsolute.ca they have an expert help section, i explained my problem and they sent me a detailed tutorial with a video that made fixing my car a breeze.
Auto Absolute Home Page
Mar 11, 2016 | Buick Cars & Trucks
My Frigidaire freezer is not getting cold at all.The compressor runs & the temperature inside the freezer stays the same.What can I do to try & diagnose the problem myself? The freezer is 14 yrs old &...
The thermostat could cause this fault or it could have lost its gas . A fridge mechanic could test it for you. Not much a lay person can do with out tools. May best to buy a new one.
Mar 18, 2015 | Frigidaire Freezers
How do you adjust the carburetor?
Most of the newer equipment have EPA carbs that wont allow serious carb adjustment without special tools. The tools are only supposed to be sold to service shops who will make adjustments and then put limiting caps on the adjustment screws. Anyone found defeating these systems can be fined by the EPA. If you think your carb is running a bit lean just use a little bit of choke and see if the engine picks up a bit. Then you can try mixing in some fuel system cleaner into your next tank of fuel and see if that gets you back on track. It is the cheapest way to go before spending any money on shop service or new equipment.
Be safe and good luck!
Oct 03, 2014 | Homelite Garden
How to make a corolla faster without spending money
http://www.ehow.com/how_5882439_make-corolla-go-faster.html
cams, underdrive pulleys, chip, turbo along with high-flow fuel injectors and fuel pressure reg, cold air intake
http://www.performancechipsdirect.com/Toyota/Corolla/ 69$
no real cheap way except drive down hill
Nov 01, 2012 | Cars & Trucks
Anti theft problem in a 92 cadillac?
Go to this link for alot of info
http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 30, 2012 | Cars & Trucks
My dsi has gotten wet can this be repaired without spending alot of money?
then do it and buy what ever you're talking about or get a grage sale set up and get money there or get money from job (if adult) and just what i said was not in a mean way
Sep 12, 2011 | Dsi Orange Console
I own a 2002 hyundai elantra. one of the radiator fans is no good and i removed it. i want to replace it but i dont want to spend the money on a fan if my problem is gonna be HUGE...ONLY when it's warm...
Replace the bad fan what money you spend now is nothing compared to a new engine. Heat is the issue. If the motor only needed one fan to begin with they wouldn't have put two one radiator. Also alot of cars have one fan for the ac and one fan for cooling so without seeing the setup not sure. But I strongly advise replacing the fan that is no good asap.
May 06, 2011 | Car Audio & Video
I want more power out of my 1999 wr 400 without spending alot of money
buy a bigger sprocket on the back and a smaller one on the front this will increase the acceleration try this i did heleva fun hope this helped bud
Sep 07, 2009 | 2000 Yamaha WR 400 F
What can i do to get a new screen without spending alot of money
you may be able to find one used at a local repair shop as most shops save them when they part out rear projections that arent worth repairing. Other than that replacement screens are several hundred dollars if you can find them.
Jun 14, 2009 | Toshiba 55H70 55" Rear Projection...
Running hot
MY LS-400 IS RUNNING HOT WHAT CAN I DO TO SOLVE THIS PROBLEM
Jan 15, 2009 | 1995 Lexus LS 400
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
2,213 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
