Question about Canon PowerShot S5 IS Digital Camera
Hand shaped icon in bottom right corner of Canon powershot S5 SI digital camera
What does the hand-shaped icon inthe bottom towards the right mean? I cannot find the icon in the user guide
That is wind noise off
Posted on Mar 13, 2008
It sounds like the image stabilization "on" indicator.
Posted on Oct 15, 2007
How to pair bluetooth device
First, make sure Bluetooth is enabled on your Lenovo. Right-click on the wireless connection icon in the Windows system tray. The icon is usually a wedge-shaped icon showing signal strength bars. The icon is usually located at the bottom right corner of the taskbar at the bottom of your screen. So, right click on that icon and select Open Network and Sharing Center. In the new window locate and click on Change adapter settings on the left-hand menu. In the new box that opens search among the tabs for information to confirm Bluetooth is "enabled".
Next, according to Sony's help guide try the following:
Unable to connect the speaker to a BLUETOOTH device with One-touch connection (NFC)
Keep the smartphone close to the speaker until the smartphone reacts. If you fail to connect, move the smartphone
slowly on the N-Mark of the speaker.
Check that the NFC function of the smartphone is set to on.
If the smartphone is in a case, remove it.
NFC reception sensitivity varies, depending on the device. If you repeatedly fail to connect the speaker with a
smartphone by one touch, connect it to the speaker by on-screen operation.
Check that your smartphone is compatible with NFC. Look up information on the issue on the customer support
Sep 27, 2014 | Lenovo Computers & Internet
Where is the menu touch button located of 191EL phillips
Per user guide on page 5 at the bottom left column it sates "buttons at the front bezel of the monitor" So it could be the imprinted icons on the bottom right hand of unit as shown on the picture or underneath it.
Dec 14, 2012 | Computers & Internet
Cant unlock tablet t301
I'm not exactly sure what you mean by "unlock". But, if you mean you see the main screen but don't know what to do next, that's easy. On the home screen you will see two icons down toward the bottom, one on the left (green, with a little picture of a lock which has an open hasp), this is the UNLOCK switch. Simply put your finger on it and drag to the right, then release. The other icon is gray and controls the volume. See the user manual here, and picture of the screen I am talking about is on page 7. Post back if this isn't what you were looking for. No reset necessary
Aug 12, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
What are the steps to replace a chain on a Husqvarna 345 chain saw?
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, now remove the two 8mm nuts securing the side cover, screw the chain adjuster in the crankcase fully back toward the sprocket, assemble the guide bar over the guide bar bolts and slide it fully back toward the sprocket, now loop the chain over the sprocket and lay it inthe guide bar raiuls and around the guide bar nose, make sure the sharo endge of the cutters on the top of the guide bar are facing away from the machine ( as you loog at it, it rotates clockwise ) now align the hole in the guide bar with the adjuster pawl, re assemble the chainbrake side cover back onto the saw, and fit the bar nuts finger tight, adjust the chain adjuster so as the chain is a snug fit all the way around the guide bar, with a gloved hand pull the chain around the bar manually, so as to make sure it is completly seated in the sprocket and bar rails, re tension if needed, hold the tip if the guide bar up and fully tighten the bar nuts.
Job done.
Jan 23, 2011 | Husqvarna Garden
What is the hand icon on the bottom right side of my camera mean? (It's not the shaking camera icon) I can't find it in the user manual anywhere. It's a solid white hand.
See pages 20 and 39 in the manual. According to this, the hand symbol indicates that you have Image Stabilization set in the 'Continuous' mode (always on). The other modes available are 'Shoot Only', 'Panning' and 'Off'. You select the desired mode at 'IS Mode' on the Menu for Record (camera silhouette at the top) .
Feb 25, 2010 | Canon PowerShot S3 IS Digital Camera
Icon of a shaking hand on LCD screen
The shaking hand icon has to do with the Image Stabilization control.
If it's continuously shaking, it's set in continuous mode, etc.
You can access control for the "I-S" via the menu...scroll down to IS settings. and you can adjust as desired.
Dec 10, 2009 | Canon Cameras
I need to download a users manual for a Electrolux EW1055F washing machine for free
Hello michael360,
Copy and paste this link Towards the right side of the page you will see a pdf icon to download the manual. Hope this helps.
May 02, 2009 | Washing Machines
How do i turn off predictive text on a samsung cellphone?
well my phone is D900 and to turn it off predicted i just hold on the star at the bottom and it changes
hope thats helped but it might be different for yours.
Dec 16, 2008 | Samsung SGH-D900 Cellular Phone
Flashing led
it could mean a lot of things. it could mean that:
1. there are cartridges installed.
2. the cartridges are not properly installed.
3. the access cover/scanner lid is open.
among others..
for more solutions, please check the user's guide.
Sep 14, 2008 | Lexmark JetPrinter Z55 InkJet
Canon PowerShot S5 IS Digital Camera Logo
1,041 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
