Question about Canon PIXMA iP1300 Printer
An Ink cartridge is not installed properly and the ink cartridge cannot be recognized
  • joce35 Apr 28, 2009
    yah we have the same problem with this printer.i already reset the printer but it doesn't work out at all. what's the solution to this problem pls.
  • Karl Wright
    Karl Wright May 11, 2010
    Have you installed a compatible cart instead of an original Canon cart?
Buy 1liter of gasoline and pour it on your IP1300 and then fire it up... I have the same problem and I already solved it! Canon is wasted!!! Just buy other brand.
Posted on Jan 02, 2011
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
The ink cartridge cannot be recognized ,but the ink cartridge was installed properly .Unfortunately,the ink was flowed out ,please tech me a proper manner to comb this problem as soon as possible
Hi, are you using the original ink cartridge or your ink was modified to CISS before? If you just finished refill your ink and this problem occur - the ink cartridge cannot be recognized, you shall take out both your ink cartridge and try to wipe the whole thing with a clean cloth and then carefully put in back. Hope it helps you. Good luck =)
May 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Whats the meaning of error in canon e5 error?
"E5: The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur."
Jul 22, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
Color cartridge recognition MP160
E5
5 times
The ink cartridges are not installed [1401], or a non-supported ink cartridge is installed [1485], or the ink cartridges are not installed properly [1687].
Check if supported ink tank(s) is installed, and re-install them properly, and then close the scanning unit.
Sep 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Ink Cartridge not recognized
Use only Genuine HP ink cartridges.
Apr 11, 2008 | HP 1040 Plain Paper Inkjet Fax
Canon PIXMA iP1300 Printer Logo
2,375 people viewed this question
old marine
old marine
