Question about Dishwashers
Bosch dishwasher has water in it after finishing a cycle. Is this normal or is there a problem
I have a bosch dishwasher and after it finishes a cycle there is still water in the bottum of it. I just moved into this house and am not sure if this is normal or if there is a problem
  • 423 Answers
All dishwashers leave a small amount of water in the sump area to keep the rubber/plastic connections lubricated.
As long as the water is clear and has no odor, you have nothing to be concerned about. OK?
Posted on Apr 21, 2009
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Dishwasher goes through cycle but when finished it is cold and code E..09 appears
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Jul 26, 2015 | Bosch Dishwashers
Dish washer goes through cycle but when finished cold with Code E..09
My Bosch dishwasher Model #SHX4APO5UC/06 wont finish the cycle and it wont drain. We have checked hoses and they are not clogged. Is it something with the control panel?
Check your motherboard for burnt contacts. Easy to remove in the door. If you able resolder and give it a try. Cheaper then a new mother board.
Aug 11, 2014 | Bosch Dishwashers
Should any water remain under the glass trap after cycle has finished on a frigidaire dishwasher?
Good Afternoon Friend,
I understand that you want to know if any water should remain under the glass trap, on your Frigidaire dishwasher, after the cycle has finished. Per the owner's manual, "it is normal to see a small amount of water under the filter at the end of a cycle." Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Dishwashers
Water not emptying
check if the dishwasher is level. designed to drain correctly under level conditions.
Apr 21, 2012 | Bosch Dishwashers
I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Our Bosch Dishwasher Not Draining After Normal Washing Cycle
make sure the filter is not blocked by anything like a straw or just junk
Apr 02, 2009 | Bosch Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Exxcel Dishwasher
no not if it getting hot it still sounds like the motor isnt coming on put the spray arms in the same position turn it on then open the door are the arms still in the same position or haved the moved.those cleaners need hot moving water to melt the seal.
Aug 30, 2008 | Dishwashers
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
