Question about Fuji FinePix S5100 Digital Camera
Fuji s5100 batter door cover prongs are broken off.
Can I get a replacement cover, and how much does it cost with shipping or should i just take it to a repair shop               /
  • JianB Apr 24, 2009
    Camera fell and the prongs that lock the lid into place when closed down are all broken. A rubber band is currently whats holding the batteries in place - not a pretty sight.
    Can this be repaired? Where?
I have the simple and cheap fix to a frustrating problem!
Just take a tripod base and screw it into the bottom of the
camera. The square tripod base is large enough to hold the battery
cover on the camera closed without any interference.
So there you go! No tape, rubber bands or other crazy contraptions!
Cheap, Quick and simple.
Steve in Tampa, FL
Posted on Aug 05, 2009
  • mirelg Jun 25, 2011
    good solution that worked for while till the metal screw of the tripod broke the plastic plastic filament of the camera hole; the weight of 4AA batteries is too much
I have a s5500 with the battery lid clips broken.. fuji says ,, nope no warranty on that part ,, what a joke,,$120 dollars labour plus parts and freight for repair... anyway ,, went to jaycar (electrical supplies etc) and found a small metal clip/ fastener that I used on an existing exterior screw below where the strap is located. i then placed another screw in the lid that allows the remainding hole in the fastener to slip over, works like a charm. took me around 3 minutes to do and does not affect the grip on the camera and still alllows it to be easily opened and closed. I am most pleased i now have my camera back.
Posted on May 01, 2009
  • Bill Dickerson
    Bill Dickerson Jan 25, 2012
    Can you be more specific on the parts you used for the repair.
  • ALONDRA ESCOBEDO
    ALONDRA ESCOBEDO Feb 09, 2015
    CAN YOU PLEASE LET ME KNOW HOT TO REPAIR IT?, I HAVE EXACT THE SAME PROBLEM
Can you replace the battery compartment.
contact fuji and ask their customer support . , sounds like a costly fix .
Mar 23, 2016 | Fuji FinePix S5100 Digital Camera
My Fuji Finepix S5100 camera keeps losing its settings and date and time when the batteries die. Is there a small "watch" type battery that can be replaced so it can keep its memory?
There is no "watch" battery in the camera. Always keep fresh batteries on hand and switch them out quickly. That usually solves the problem.
Mar 08, 2011 | Fuji FinePix S5100 Digital Camera
The battery door clips are broken where can i get a replacement door
not sure who is in charge of inventing these, most annoying indeed. glad to hear you are replacing, trying a piece of tape etc can damage all sorts of stuff without you even noticing.
check out: http://www.teleplancamerarepair.com/manufacturer/repair-camera-model-problems.asp?mo=302
They have a blog that talks exactly about that too!
May 29, 2010 | Fuji FinePix S5100 Digital Camera
S2000hd batter door. One of the little plaastic "clips" on the canera body that the battery door latches into has broken and the door does not stay closed the way it should. Fuji tells me no warranty, body...
Get a piece of flat aluminium or steel approx 2 inches long, drill a hole at one end and use the Tripod socket to hold the flat steel down, over the batery lid to hold it shut.
Jun 22, 2009 | Fuji FinePix S2000hd Digital Camera
Need complete copy of Fuji finepix S5100 manual
which safe manual , u mean product manual for S5100 user manual
see this link and download ur manual from here
1.
FinePix S5100 Manual
Manual for FinePix S5100|PDF|8 MB|
spacer.gif 2.
S5100 & S5500 Quick Start Guide
Brochure for FinePix S51002 Pages - 1 MB|
Mar 28, 2009 | Fuji FinePix S5100 Digital Camera
Turn off date and time mode
http://www.rug.nl/rechten/voorzieningen/audiovisueledienst/productendiensten/handleidingen/finepix_s5500_manual.pdf
here is the link for the manual to fuji finepix s5100. download it and go to page 72. it will step you thru the sequence. very easy.
Mar 24, 2008 | Fuji FinePix S5100 Digital Camera
Battery lid or cover
Feb 10, 2008 | Fuji FinePix S5100 Digital Camera
Battery cover
I had a look at my S5000 and see what you are talking about. Those tabs are part of the inner shell, likely expensive to replace if even cost effective. In the past, I have cut the broken tabs off, leaving a flush surface. I then drill small holes and insert large head screws that I file to match the door tabs. It does require some finite work but is possible without disassembly of the camera.
Jan 22, 2008 | Fuji FinePix S5000 Digital Camera
WILL NOT COME ON
Do you have the batteries inserted properly? That is, correct polarity?
Aug 29, 2007 | Fuji FinePix S5100 Digital Camera
Fuji FinePix S5100 Digital Camera Logo
1,124 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
