Question about Sony Acid Pro 6 Professional Music Workstation Full Version for PC
Acid Pro 6.0 freezes when it is "scanning for cd devices"
Whenever I try to extract audio from a cd on Acid Pro 6.0, a box pops up that says "scanning for cd devices" and then my computer freezes. Please help!
In Acid Pro 6 Click Options, Preferences and under the General Tab Check Box That Says "Use SPTI For Direct CD Burning".
Problem Solved!!
Posted on Jul 04, 2011
Cant Extract From CD!!!
There is a program called IsoBuster.
It can extract data from cd.
Please give it a try.
The link is given below.
https://www.isobuster.com/
Jul 02, 2017 | Sony ACID Music Studio 6.0 (ASAC6000)
Tip
How to enable CD digital audio extraction (Digital CD Audio Playback) 1. Click...
1. Click START / SETTINGS / CONTROL PANEL / SYSTEM.
2. Click the HARDWARE tab.
3. Click DEVICE MANAGER.
4. Click the plus (+) to the left of DVD / CD-ROM DEVICES and double-click your CD-ROM drive. Note you can also right click and select Properties.
5. Click the PROPERTIES tab and toggle ENABLE CD DIGITAL AUDIO EXTRACTION FOR THIS DRIVE.
6. Click OK
Repeat steps 4-6 for any other ROM drives listed in Device Manager.
Note you may need to reboot your computer for the change to take effect.
At this point CD digital audio extraction should be enable and you do not need to have the CD audio cable connected between your ROM drive and sound card. Note if you have an older computer (CPU under 1G) then you may need to have CD digital audio extraction turned off because your computer may not be able to handle the data from the CD on the system bus.
on Jun 01, 2010 | Computers & Internet
Installing Logitech pro 9000 webcam without CD - having troubles.
Ok maybe you can try this:
- get the software for the camera and extract into a folder in desktop (to keep it at hand mainly)
- plug in camera and wait for the Guide to a new device thingy, where it asks you to insert cd.
- now most times the computer asks you to insert cd or indicate location of installation folder, instead of cd, try to look for an option to browse to the directory where you extracted the files.
If that works, you will be able to get the basic drivers installed and when you restart, guide won't appear anymore because won't be a new device, and then u could install additional software.
Mar 14, 2017 | Logitech QuickCam® Pro 9000 Personal Web...
I can't hear the instrumental track when trying to record vocals on acid pro 6. What am I doing wrong?
you need to switch the monitor when playback on in the audio properties.
& use headphones to stop any feedback.
Sep 10, 2011 | Sony Acid Pro 6 Professional Music...
It won't extract m cd. it just says scanning for devices and nothing happens
For stuck CD do this:
Hit Ctrl,Alt and Delete all at the same time> Windows Task Manager should open> Click on the "Applications Tab"> Click End Task to close all Apps.> Now go to your Cd/Dvd player hit the eject button on the front.> Remove CD.
Now for your device problem try this:
To specify your preferred audio devices for playback or recording in Windows, do the following:
Windows 98, 98se, ME:
1. In Control Panel, double-click Multimedia or Sounds and Multimedia.
2. On the Audio tab, select the devices you want in the Preferred Device boxes.
3. Click the Use Preferred Devices Only check box to select it.
4. Click OK.
Windows 2000 and XP:
1. In Control Panel, double-click Sounds and Audio Devices.
2. On the Audio tab, select the devices you want in the Default Device boxes.
3. Click the Use only default devices check box to select it.
4. Click OK.
Windows Vista:
1. Go to Start > Control Panel
2. In Control Panel, select the option that says Hardware and Sound
3. Under the listing for Sound, select Manage Audio Devices
4. Under Recording and Sounds tabs, you will find all available devices. To set a default device, right click on one of them and select Set as Default Device.
Windows should now be configured to use these devices for both playback and recording.
This should fix your problem, if not use link to go to Sony support. Use the E-Mail option for a faster solution.
http://www.sonycreativesoftware.com/support/
Oct 08, 2010 | Sony Sound Forge 8.0 for PC
Serial Number...
Did you misplace yours, or are you trying to pirate a copy? It's on the CD sleeve, box, or was emailed to you. If you registered it, try here
http://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/popup_adp.php?p_faqid=506&p_created=1041919200
Jan 18, 2009 | Sony Acid Pro 6 Professional Music...
Acid pro and vista (inspiron 1720)
Sony says the operating systems listed on the box -- the ones out at the time you bought the software -- are the only ones supported:
http://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/std_adp.php?p_faqid=2651&p_created=1165596321&p_sid=gFBkVDkj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjQsMjQmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9dmlzdGE*&p_li=&p_topview=1
-That- said, some people apparently have gotten Acid 6 working.
You have Acid 5. It won't hurt to check and update some other things, whether you're able to run Acid or not. (And if your computer is strong enough, you may be able to run XP in a virtual machine, but that's a whole 'nother story.)
First, click your volume control -- likely in the bottom-right corner, or through Start: Control panels, and ensure your "line in" level is set high and the mute is not off. Yeah, you probably did this. Please quadruple check.
Try Start: Control Panels: System: Device Manager. See if you have any little warning signs or Xs next to any of your devices.
You can also look in the audio device section and see what your sound card is. (A Dell made one day may have completely different guts than a Dell of the same model made a few weeks earlier.) You can take that information and download a new driver from the company, which will have more updated drivers than Dell.
Last, make sure you've installed the latest updates to Acid 5. It won't hurt, and might make a difference. Doubt it, but it might. And if you go the virtual machine route, you may benefit there from the marginal improvements:
http://www.sonycreativesoftware.com/download/updates/acidfamily
Nov 03, 2008 | Sony ACID Pro 5 for PC
MSI blue box pops up and disables the internet what device are you installing line out
Download a self-extracting copy of HijackThis from here
http://downloads.malwareremoval.com/hijackthis_sfx.exe
Save it to your Desktop.
Double-click on the file hijackthis_sfx.exe file and it will self-extract into its own folder ……
C:\Program Files\HijackThis
Go to this folder and run the hijackthis.exe file.
From the menu click on "Do a system scan and save a logfile".
Copy and paste the HJT logfile to this thread. More specific removal instructions will follow.
Good Luck, Please dont for get to vote, Thank You
Dec 14, 2007 | Intel Motherboard
Sony Acid Pro 6 Professional Music Workstation Full Version for PC Logo
346 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
