Question about Intel Motherboard
Upgrading BTX Motherboard
I wanted to upgrade my Dell Dimension 3100 motherboard. I have all the internal cables connected, but I can't find a way to connect the power on/off (not the power supply), but the button you use to turn computer on and off. The connector for the old motherboard uses an IDE cable, but the new motherboard which is compatible for the Dual Core 2 Processors, has a 9-Pin front panel connector. Thanks for any suggestions...??
    Novelist:
  • 231 Answers
Hi, I think you are looking at the front USB pin aray connector. The on/off switch and LED light pins are usualy along the edge of the board nearest the front of the case. They will be marked with ID: lettering:- pwrs, hdd led, rs-sw, pwr led. If your case has one block plug you will haave to gently seperate the segments and plug them on one at a time. The power and reset switch will work either way but the LED will only work when plugged the right way around, it wont do any harm if they are plugged backwards they just wont work, so experiment. regards mistyman
Posted on Sep 22, 2007
SOURCE:
Dell dimension maximum cpu upgrade
http://www.cpu-upgrade.com/index.html
You will need to type motherboard name ID and the cpu ID
Significance
Upgrading to more modern operating systems depends on the type of processor in the computer.
One of the main differences between the two systems is that a 32-bit operation requires either a 32-bit or 64-bit processor, while a 64-bit version must have at least a 64-bit processor.
Identification
The operating system will register different on each computer that is running the platform. When a user clicks on the Start button, they can go to the Control Panel, followed by the System and Maintenance tab and click on System.
This will show whether the computer is running a 32-bit or 64-bit operating system
Hope this helps.
Nov 29, 2012 | Dell Dimension 3100 PC Desktop
Can i change out the motherboard on my dell dimension 4600 and use the one from my optiplex gx 520 in place of it.
No you can't. The Optiplex system board is a BTX type, and the Dimension uses an ATX style. The BTX board was supposed to be the new standard, with the layout changed to improve cooling air flow. Unfortunately, the I/O connectors (keyboard, etc.) aren't in the same place as on ATX boards, and you can't just drop the BTX board into the same case. (This is one of the reasons the new design didn't catch on. Seems people didn't like the idea of shelling out for a new case as well as the board.)
May 28, 2011 | Dell Optiplex GX520 (XG309) Motherboard
Dimension 5150 (DIM515MIN) PC Desktop: I want to know what kind of case a dell has. I'm p...
The Dimension 5150 has a BTX case, which is nearly impossible to upgrade. The motherboard is NOT interchangeable (with a few exceptions, but none of which are true upgrades).
If you have a PCI Express slot, you can upgrade the video card but do not get a card that requires an additional power cable directly from the power supply. This is because the stock power supply is very weak and doesn't have outputs for additional cards. If the card requires no additional power, you should be fine.
You can upgrade your processor with the P4 [Prescott] 5xx or 6xx Series Processors with HT. The 5150 does not support core 2 duo processors. Depending on what you currently have, this may or may not be worthwhile. Also note that higher power processors run at higher temps, which sometimes causes a noticeable increase in fan noise.
The hard drive is easily upgradeable. Just buy any standard sized SATA hard drive. Your computer case supports two drives, so you could keep your current drive and just add a second drive. Remember to buy a SATA cable with the new drive because new drives usually don't come with them.
Overall, if you're looking to get outstanding performance, get a new computer. BTX computers are not gaming computers. You'll end up dumping money into this thing just to get a lousy increase in performance.
May 18, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 4300 PC Processor upgrade
if the sci36-r13 is the stock mobo that came with that pc it isnt worth upgrading
pentium 4's use the LGA-775 socket this is compatible with all pentiums and core 2's (not includeing core i7), so you could put in a core 2 quad if you wanted to but it would not make much difference to performance because your motherboard would not be able to handle some of the fetures
your ram would also reduce preformance
if you wanted to upgrade that computer you would have to replace everything but maybe the case
Oct 12, 2009 | Dell Computers & Internet
How do i hook up lg/gh22 super multi dvd rewriter to my dell dimension 3100 The cords are not the same
The drive you are installing is a SATA drive. The system came with a PARALLEL ATA or PATA optical drive, The motherboard has a SATA controller and the HDD is a SATA drive. So you need a SATA data cable and connect it to the SATA 1 port on the motherboard. There should be a SATA power connection inside the chassis that is not being used, that you can connect to the drive. Then go to system setup (F2 at boot) enable the SATA 1 controller and disable the PATA controller
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1043338
Oct 05, 2009 | Dell Dimension 3100 PC Desktop
Upgrade a dell dimension 4500-p3 motherboard to a duo or quad motherboard
You can do this with case modification as well as a new psu as Dell used proprietary mb's, psu's & cases on this model Dimension. To tell you the truth it would probably be cheaper and easier to pick up a core2duo or quad barebones kit than trying to modify the Deimension. Just my opinion. Remember Dell psu's are not wired the same as industry standard and their motherboartds in these older units are not top quality. Hope this helps you out.
Jul 08, 2009 | Computers & Internet
Change Motherboard For Dell Dimension 5150
If you replace with the same motherboard that's in already, that would be easiest for you.
But if you use a different one, you'll have to re-activate Windows, and download and install new device drivers.
Jan 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Intel Motherboard Logo
127 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
