Question about Acer Aspire One Netbook 8.9" Notebook
Computer runs for a while, then looses HDD. Can not register.
While setting up the notebook, it restarted stating network boot location not available. I checked the settings, and no hard drive was recoginzed. I finally got it going again, but have never been able to register the product. Their web site says it is an eligal serial number and they do not start with LUS......
Anyone else have this problem?
Notebook pc states reboot from network
Hi, usually reboot from network error occurs when the computer cannot detect the hdd on the computer where the Ooperating system is installed. Try removing the ethernet cable when you restart the computer. And also remove any devices that is connected on the computer via USB. If problem still occurs. try to send the computer to a local technician to check the hdd on the computer for errors.
Thank you for using Fixya, you recommendatino is highly appreciated for the free support.
Jul 04, 2012 | HP Mini 1010NR Notebook
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
Hi , my laptop seems to have crashed , it won't load up I have a black screen with the following writing Broadcom base code pxe-2.1 v1.1.0 Pxe-e61: media test failure , check cable Pxe- m0f : exiting...
Just follow these simple steps below and it should resolve the issue.
  1. When the computer is booting, go in the BIOS.
  2. Change the boot device priority so that your HDD becomes the first boot device.
  3. Disable network PXE boot if possible. If not possible, just put it as the last boot device.
  4. Press F10 to save settings and restart the computer.
  5. If problem is not solved at this stage, turn off the computer.
  6. Remove the lid and remove the HDD, clean the pins and reseat it.
  7. If issue persists, give a tap on the laptop where the HDD is located (I assure this works and has solved many problems) as there seems to be a 'strike zone' on some HDD.
Now turn on your computer and it should be running correctly.
Hope this helps you.
May 17, 2011 | Acer Aspire 5536-5224 Notebook
When i start up my computer (Accer 4230) i get this message "UNDI PXE 2.0, Media test failure, check cable, exiting PXE ROM. The message repeats over and over and it wont start up. I don't have an...
Start the computer and hit the F2 key until you get into the BIOS. When in the BIOS you can see in the Main/general page whether the hard drive is seen by the system. You will see HDD (hard drive) CD-ROM which is the optical disk drive.
If you see the hard drive the look for boot options in the tabs. When you get to boot options set the HDD as the first boot device, save the settings and exit the BIOS.
Hopefully the laptop will restart and boot from the hard drive, thus into Windows.
If the hard drive is not seen in the BIOS then the hard drive has failed and needs replacing.
If you have a BIOS password then start the computer hit F12 repeatedly until you see the boot option menu and choose the HDD.
Regards.
Feb 09, 2010 | Acer TravelMate 4230-6499 Notebook
PXE-E61: Media test failure, check cable
This is indicative of either the HDD interface has come loose from the HDD or the HDD has failed. The code above appears when the HDD is not recognized and the computer is looking for a network drive to boot from.
Jan 07, 2010 | HP Pavilion dv1000 Notebook
Set-up recognize my hdd but windows doesn't
Windows uses NTFS file system.
you need to enter a boot disk/recovery disk/windows xp disk into your CD drive and in the system BIOS select the CD drive to boot first. Once the CD has loaded you can re-format your HDD to NTFS and re-install windows
You will, however loose all your data but your HDD will function again with windows
Oct 05, 2009 | Maxtor Hard Drive
Network Boot
hi,
i have dell c400 laptop, its to much simple to install xp
first you just take out hdd from laptop
plug in tht hdd in desktop pc by external usb box
now u just start windows 98 setup in it
when it started first format ur drive then install it
when windows 98 setup files copies to 100%. machine need to restart
u just plug out the hdd and plug in back to laptop
now the setup will remain start in ur laptop and when the installation complete u just upgrade ur windows from 98 to xp by intalling xp from external drive on OPERATING SYSTEM OF 98 WINDOWS
NOW WAT U SAY???
ITS TO MUCH SIMPLE just try once
Jan 29, 2009 | Dell Latitude C400 Notebook
HDD cange, boot error
is this the original hard drive
for boot options while in restart constantly press F7 a menu will come up high light your boot choice
you may need to run windows on the hard drive again
Jan 20, 2009 | Toshiba Tecra M2-S730 Notebook
System Restore
u can recover from the crysis by booting in safe mode after that goto control panel -Performance and Maintenance--system--in that select system restore if u hav any previous res points u r safe......otherwise a different procedure is there.............................
Nov 26, 2008 | Lenovo 3000 C200 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
