Question about Zyxel NBG318S Kit Wireless Router
Connecting two NBG318S Homeplug rourters
I want to connect two NBG318S HomePlug Routers in the following manner. 1) First one connected to the ISP via Ethernet WAN port 2) Second one need to connect or share the same internet through First unit via Homeplug Technology. 3) The Second Unit should be able to Serve to the WiFi accessible devices. 4) Units connected throgh the Second Unit Ethernet or WiFi need to have IP Addresses generated/Managed by First Unit. 5) Should be able to access the Unit 1 or 2 for managing the network at any time.
5 Suggested Answers
  • 700 Answers
SOURCE: can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
Posted on Apr 08, 2009
kakee
  • 1269 Answers
SOURCE: Zyxel 660HW DSL LED keeps flashing
Try to change the Local or LAN IP Address of your Zyxel to 192.168.5.1 and do not configure the Zyxel router for PPPoE Connection. It should be configured as Obtain IP Automatically or Automtic DHCP.
Posted on Oct 23, 2009
Testimonial: "Thanks for your repsonse."
Geekman
  • 32281 Answers
SOURCE: i need help connecting ps3 to innoband homeplug av
The encryption (WEP) key is configured in the router's wireless settings.
I suggest you use WPA or WPA2, these are later and much stronger encryption methods than the older WEP encryption.
Posted on Oct 12, 2010
  • 8 Answers
SOURCE: My Linksys router works fine
Howard, your router maybe set up or configured improperly. I would suggest to completely reset the router to its factory settings and start over. There is a small reset button on the back of the router. The ip subnet may be conflicting with another subnet or your NIC might be configured with a static ip address conflicting with an ip on the router. As indicated in another post, there seems to be more information needed to answer this question fully. I would attempt to reset the router, although you will have to reconfigure the wireless settings again after you do this but it will determine whether it is the routers problem or your laptop that needs to be configured differently.
Posted on Sep 29, 2011
Homeplug
what password are you referring to... if you mean the actual internet connection thru your provider you will need to contact them and provide all your details correctly that they ask for.... ask them to reset your password.... and then use that to gain access
Robert
Sep 20, 2008 | Computers & Internet
How do i fix after modem reset
Basically, you unplug all of the Netgear Xe104 units, wait a minute, then plug the one nearest to the Router back into a wall socket first. Wait a few seconds then plug in a second Xe104 and give it a minute to "talk" to the first unit. Then plug other Xe104's in one at a time. Below you'll find the official troubleshooting steps which you should read carefully if the basic steps above do not resolve the problem.
Also, i should tell you that Powerline adapters such as yours have improved greatly in the last few years, and you can buy a pair of new ones that are very, very much faster than yours for a very modest cost. For example, TP-LINK TL-PA4010KIT
or NETGEAR Powerline 500 1-Port Starter Kit (XAVB5201) or
ZyXEL PLA4225 4-Port 500 Mbps Powerline Gigabit
XE104 User Guide 4-2 Troubleshooting v1.0, September 2005
Power Light Not On Make sure that, if power to the AC power outlet is controlled by a wall switch, the wall switch is in the on position. Verify that the wall socket is live by disconnecting the XE104 85 Mbps Wall-Plugged Ethernet Switch and plugging in some other electrical product, such as a lamp or a hairdryer. If the error persists and you have confirmed the power outlet you are using is live, you have a hardware problem and should contact technical support.
HomePlug Light Not On If the power light is on but the HomePlug light is not, check the following: • Make sure that power is being provided to more than one PowerLine device. Another PowerLine device must be installed for successful communication across the PowerLine. • Verify that the network password is the same on all devices in the PowerLine network.
Ethernet Light is Off • Make sure that the Ethernet cable is plugged in properly at both ends. • Be sure you are using the correct cable on the router that the first XE104 is connected to. When connecting the router's Internet port to a cable or DSL modem, use the cable that was supplied with the cable or DSL modem. This cable could be a standard straight-through Ethernet cable or an Ethernet crossover cable. • On attached Ethernet device or network adapter card, check that the Link light is
Feb 25, 2015 | NetGear Xe104 Wall Plugged Ethernet Switch...
LAN connection shows "Unidentified network" when connecting through Aztech Homeplug
Check the network Cable type which you used to connect the Homeplug to Router, Check with both the type of cables (Straight and Cross) and Let me know if it works
Mar 06, 2014 | Computers & Internet
I have had a pair of Belkin Powerlive AV adapters (F5D4072) for a while now and they work really well across my house between two routers. I recently bought a 2nd pair of the newer F5D4074 adapters (old...
There are two standards for powerline: HomePlug 1.0, which has a maximum link speed of 85Mbps and HomePlug AV, which has a maximum link speed of 200Mbps. You can use the two standards within the same building, but they are not compatible with each other.
HomePlug 1.0 - F5D4050, F5D4070. Powerline Turbo (F5D4071, F5D4073)
HomePlug AV - Powerline AV (F5D4072 + F5D4074 + F5D4077 + F5D4081). Powerline AV+ (F5D4075 + F5D4079) + Powerline HD (F5D4076 + F5D4078) and Powerline HD500 (F5D4085)
May 31, 2011 | Belkin F5D4074 Network Adapter
Hi all I have a Thomson Router ST585v6sl. I can connect to internet via cable but not wireless. Wireless light when you turn router on is red then goes out. I can't find an option in the routers...
i have one try using an ethernet cable and put in on internet explorer
192.168.1.254 That should be the speedtouch routers page
don't click the tabs on the right scroll down and find home networks there should be two options wireless and ethernet along with all the connections click wireless (if you cant click it click the home network tab then interfaces then click your router) then in the top right there should be something called configure now this is how it should be
Interface Enabled : Ticked
Network Name (Your Routers Name)
Interface Type: 802.11b/g
Channel Selection: Manual
Allow Multicast from broadband network: ticked
Broadcast Network name: Ticked
Allow New Devices: New Stations allowed automatically
Encryption : Use WPA-PSK Encryption
WPA-PSK Encryption Key: (Any Password thats memorable)
WPA-PSK Version: WPA
Apply if theres any changes (hopefully) try that if fails try one of these three steps:
1. go on 192.168.1.254 then click the speedtouch tab then click return to factory default settings to return it to the way you had it when you first got it. (WARNING: If you dont have your internet password you will have to call AOL for it)
2. Buy a HomePlug which is an ethernet cable that uses the electric wires in your house (example. http://www.amazon.co.uk/D-Link-DHP-307AV-PowerLine-Homeplug-Network/dp/B003L78F6U/ref=sr_1_11?ie=UTF8&qid=1298768566&sr=8-11)
3. Scrap the router and try a different one thats what i did well.. my speedtouch kept crashing and i couldnt hack it anymore now i have a new router and it was the best move i did.
Hope it works for you!
Ryan
2.
Feb 09, 2011 | General Computers & Internet
I have 4 Belkin Powerline adapters, two F5D4074 and two F5D4072. On Belkin website they are declared compatible, but I can't manage to transfer the password between the 72 and the 74, with the result that...
Also try to rest the adapters and reconfigure them again.
Dec 31, 2010 | Belkin F5D4074 Network Adapter
I need help connecting ps3 to innoband homeplug av wireless n. i cant locate wep key
Oct 12, 2010 | Gateway Innoband ADSL2+ 8120-B1 Router
Netgear WGX102 Powerline HomePlug wireless ethernet bridge dead
My friend, reward your year of hard work with a new router. Yours is dead.
Dec 11, 2009 | NetGear WL |WGX102 RANGE EXTEND R Bridge
Network
hi wild11967
re homplugs let me infor you first that Homeplugs do have a minor advantage if they share the same leg but there is usually sufficient cross-coupling.Larger commercial buildings often have 3 phase where each phase has its own transformer. Homeplugs need to be on the same transformer.
Also Long extension leads will degrade the signal so it is best practice to plug the HomePlug directly into a wall socket As with the figures youve given above you dont NEED to purchase a new equipment such as a router as youd have the same issue with it.
Best thing to to check your circuitry as - limitations are as follows - the rings or circuits (such as upstairs and downstairs) mains must be on the same fuse box / consumer box.
If you have further questions let Fixya answer it for you .
Best wishes .
May 31, 2008 | NetGear WGR614 Wireless Router
Zyxel NBG318S Kit Wireless Router Logo
331 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
