Question about Exercise & Fitness
When using the treadmill it shocks you - Exercise & Fitness
  • biglowfamily Apr 21, 2009
    The treadmill has a 3-prong plug. It is not plugged into a GFCI outlet, but it is plugged into a 3-prong plug. How can I make sure it is grounded properly. Also the treadmill is not in the garage or basement, we are trying to use it in the bedroom.
  • dennis_lange May 11, 2010
    You have an electrical short to frame occuring. Any short should be carried away from the equipment by proper ground. Does the treadmill still have a 3 prong plug-in and is it plugged into a grounded outlet and not an older 2 slot outlet? Is the treadmill being used in a basement or garage and plugged into a GFCI outlet?
    Sniper:
  • 52 Answers
The proper grounding is where the electrical cord enters the treadmill a green ground wire should be attached to the metal frame. Any short in the machine should be safely carried away from the equipment by proper grounding. If the treadmill has been properly grounded, then the problem is in the wall outlet. Your local Hardware store sells an inexpensive small device (approx. 1" x 3") with rows of small yellow, red, and green LEDs. It has 3 prongs on one end to plug into a wall outlet to check for proper grounding. On the unit there is a guide to tell you which lights should be lit. Use this device to check all of your outlets in your home for safety.
Posted on Apr 22, 2009
I get a small electric shock each time i put my hand on the heart rate monitor on the left of the treadmill. Also happens when i h the inclune buttons on the left. Any suggestions?
Hi Pjd
Shocking problem!
Suspect that the treadmill is generating static electricity.
It is building up as you run... via the rubber mat.
Like the comb through the hair picking up tissue paper bits.
This is basically a Van De Graaff Generator.
Try attaching a wire from the machine chassis (metal) to a metal tap at your sink.
Do you still get a shock?
Not sure where you are and what your electric supply is.
I'm in Australia and our AC plugs have a third pin which is connected to our meter box which is then connected to an outside GROUND ROD.
Perhaps the AC power you are using has no ground or only a 2 pin connection. I which case I would add a three wire plug to the treadmill and the ground pin would connect to the treadmill's metal chassis by a screw or bolt.
Anti static spray may also help
Cheers
Van de Graaff generator
https://www.target.com.au/p/anti-static-spray/50563715
anti static wrist strap
Mar 01, 2016 | Exercise & Fitness
Sportcraft tx390 treadmill
If you got a shock from it, it can't be properly earthed. Check your wiring!
Jan 15, 2014 | Exercise & Fitness
Control panel shocks
This is a common occurrence as we enter the dry season. Static electricity will build up as you walk/run on your machine. There are many factors which make the problem more or less evident - the type of walking belt and deck, design of the treadmill, type of walking shoes, etc.
Some treadmills have a grounding wire from the console to the frame of the treadmill as well as a grounding wire from the rear roller to the frame of the treadmill. Check to see if these are in place, or have a qualified technician check this.
One common solution is simply to add a humidifier to the room where the treadmill is located. Raising the humidity will greatly reduce the static shock problem
Nov 30, 2013 | Endurance Exercise & Fitness
I have a bodyguard t260 treadmill and when I run on it there is a great deal of static electricity that shocks me when I touch the treadmill handles
The shock is a build up of static electricity on your body called Electrostatic Discharge (ESD). Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful or dangerous.
Nov 11, 2011 | Exercise & Fitness
Treadmill won't turn on, I get a slight shock when I click the on/off switch.
Dear Sir:
Thank you by you request, I will help you inmediately.
Please do this with very Carefully!!
The shock is a build upof static electricity on your body called Electrostatic Discharge (ESD).Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful ordangerous.
Thank you in advance, sincerely. God bless you.
IF YOU NEED FURTHER ASSISTANCE, PLEASE CONTACT ME
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Precor 9.21 Treadmill
We assembled our proform shock treadmill xt70 and when we plugged it in nothing happened. It is like it is not getting any power at all.
take the hood off and look on the controller board for lose wires not pluged in and by the off and reset switch good luck
Feb 24, 2011 | Proform XT70 Shock Treadmill New!
Cant get treadmill to unfold completely
You have gas shocks on each side of the unit need to see if they are dry and causing the unit not to fully fold down use a little machine oil on the rods this should take of it if not, either the shock are defective or some how you manage to fold the unit when the incline was not at its minimum.
1) engage key the look at incline display needs to be either 0 or 1 degree 2) if shock are defective replace shocks. Hope this help!!
May 14, 2010 | Proform 730 Folding Treadmill Model...
Have a sportcraft tx350 treadmill and it won't stay on one speed. It speeds up.
I have a TX350 sportcraft treadmill and I keep getting shocked when I use it. How can I stop it ? I no longer have the user manual for it either. Can I get one ?
Feb 25, 2010 | Exercise & Fitness
Exercise & Fitness Logo
793 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
