Question about Intel Motherboard
MSI K9N4 SLI-F / Vid Card question
I'm getting a MSI K9N4 SLI-F mobo and I have all the hardware except the graphics card. I have a few Q's if I may: - will ganing performance be better using a Geforce 8800GTS SLI ready PCI-E x16 card or using two SLI cards together but of earlier release such as the 7600GT? - I can't find any reviews of the MSI K9N4 SLI-F mobo, would you know which SLI graphics cards (both DX9 & DX10) have been proven to be compatible with this mobo? - I've read alot about the on-board audio chip installed on mobos these days. Are they really as good as the write-ups say or is a sound card still needed (I'm a musician and record using Audio Studio 7 @ 44KHz)? here's the hardware list: - MSI K9N4 SLI-F - AMD Athlon 64 X2 Windsor 4200+ 65W AM2 CPU - Kingston 1GB 800MHz DDR2 Non-ECC CL5 (KVR800D2N5/1G) - Western Digital WD400BD SATA 3.0 HD - 400W power supply - SB Audigy Platinum Sound Card - Windows XP Pro THANKS for any help you can offer Gary
  • woowoo Sep 21, 2007
    the first Q should have read, "will gaming performance ..."
    Novelist:
  • 231 Answers
Hi, for the best graphics always go for dual graphic cards. This is the best way to obtain realistic 3D effects. The onboard audio chips is every bit as good as stated, MSI systems are equal to the best but at a lower price. The only change I can see that you need to make is to install a better power supply. A minimum 500w is needed with your system and if your budget allows then anthing up to 600w. Have fun with your games. Regards mistyman
Posted on Sep 22, 2007
SOURCE:
Does the MSI K8n NEO4 Platinum SLI motherboard support the Geforce GTX 550 Video Card?
The MSI K8N NEO 4 Platinum Edition mobo, has an AGP graphics expansion slot. (Accelerated Graphics Port)
It uses AGP graphics cards that are either 4X, or 8X. (Supports 1.5 Volt AGP graphics cards, hence 8X)
http://www.msi.com/product/mb/K8N-Neo-Platinum.html#/?div=Detail
Click on the Specification tab. Look under the bold - Slots - subheading.
(Overview, { Which is the tab it automatically opens to}, Specification, Download, Support, News and Awards, Where to Buy )
This is Evga's version of the Nvidia GeForce GTX 550,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
Click on the Details tab. (Overview, Details, Feedback)
Under the bold - Interface - heading, and to the right of the subheading - Interface, we see the interface is - PCI-Express 2.0 x16.
Tells you a lot right off the bat, if you know what you are looking at.
1) The graphics expansion slot you need on your motherboard, is a PCI-Express x16 slot.
You have an AGP graphics expansion slot. (That uses either 4X, or 8X AGP graphics cards)
2) The PCI-Express technology used is PCI-Express 2.0
Therefore the answer is No, Stephen.
[ More info on AGP graphics technology, and PCI-Express technology,
1) AGP:
http://en.wikipedia.org/wiki/AGP
2) PCI-Express:
http://en.wikipedia.org/wiki/PCI_Express
Now if someone asks you, why the GeForce GTX 550 graphics card will not work on your motherboard, you can explain why in detail, instead of just saying some dude/dudette on FixYa, said it will not work.
Are you sure some 'Mom and Pop' computer store will not trade out, a decent AGP graphics card, for the Nvidia GeForce GTX 550 you have?
Always worth a shot. Just MHO.
Regards,
joecoolvette
[ For additional questions please post in a Comment ]
May 25, 2012 | MSI : K8N NEO4 Platinum SLI/S939/nForce4...
MSI K9N4 SLI Motherboard
It's easy to replace but I don't know how easy is to find a fan like that. Search first of all to find one and then remove it. Why don't you try a good cleaning with a soft brush and a vacuum cleaner or air under presure. In the last case let the motherboard to dry after the air.
Stelios.
Feb 20, 2010 | MSI K9N4 SLI-F Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Can a Gigabyte K8N Pro SLI mobo support a PCIe 2.0 video card?
Hi Rachacha!
I have lait a few moths.
Off course, you can use the pcie 2.0 card on pcie 1.0-1.1 mobo, but the card effiency is only 90%, because the mobo have not enough power for the card.
Best regards
Kommy
Mar 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
Graphic card heating problem
Cards can over heat but usually not only purchase 2 cards if $ & mobo allow while xfire / sli Graph are great most games are fine on a 512 to 1 gb card anyway and also bdepends on the cpu mobo combo that goes with it
Oct 22, 2008 | Computers & Internet
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
CANNOT SET UP SLI MODE
So it sounds like you are able to enable SLI mode, but once you do, you have no video output (upon reboot). The most likely problem is that it's now in SLI mode, but your monitor cable is hooked up to the wrong video card; try changing it to the other video card, and see if you have output from that one.
Sep 19, 2007 | Gigabyte GA-8N-SLI Motherboard
MSI K9N4 display garbled
Hi, have a real close examination of the capacitors on the board. [round things that stand up in groups] if any of these are buldged out on top or bottom discard the board. If they are ok just fit another CPU and you should be ok, MSI make a reliable and very stable board. I have used them for several years without any problems. Regards mistyman
Sep 06, 2007 | Intel Motherboard
Intel Motherboard Logo
115 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
