Question about Amana AFD2535DES French Door Refrigerator
I get a buzzig sound from the bottom of the
I get a buzzig sound for 5-10 seconds twice a minute from the bottom of the freezer around the the coil area. I have replaced the small fan last year,any idea's?
Thanks,Steve
  • sgbee Apr 21, 2009
    mod#AFD2535DES .yes it has an ice maker,it seems to be working fine,Refrigerator temp is good also!
  • sgbee Apr 22, 2009
    Everything has thawed now.Took it all apart,found that the noise was from the compressor pump.It was very hot & cooling line just a little cooler than room temp.I assume it won't be under warrenty as it's three years old now! Thankyou for your help,time to call a service tech. Steve
  • Amana Master
  • 4,655 Answers
Does it have an ice maker that is not working? The only thing I can imagine it could be is the start relay, condenser fan blades hitting something in its way or the water control valve trying to open because the ice maker is telling the water valve to open. Double check the model number above your post so I will pull up the correct manual for your refrigerator. Thanks, Sea Breeze
Posted on Apr 21, 2009
  • John Tripp
    John Tripp Apr 21, 2009
    There is only a few things I can think about. The fan you replaced, Fan blades touching something, vibration due to fan mount being loose. the ice maker acting strange, or water dispenser acting up in the door dispenser. There is very little more that could make those, because the way you say buzzing sounds like a solenoid sound. Reason I say this is there is very little behind the freezer wall other than the defrost element, defrost thermostat and those parts I have never had make a noise like that. Try unplugging ice maker from wall inside freezer or keep doing things inside freezer to eliminate the sound. That will be better if you eliminate one thing at a time until you come up on what's causing the sound. If it's one of the things that I mentioned, would be great. I just cannot imagine it being anything else. Let me know what you find, Sea Breeze
  • John Tripp
    John Tripp Apr 22, 2009
    You can salvage the compressor, but why it is so hot is wat we need to know. Was condenser and evaporator fans running? I believe that buzzing is coming from the start relay and start capacitor is bad. It wants to start so much and these parts may be the problem and need replaced. But don't go buying a compressor until you check these first. If you want the tech. will be fine but may cost you. Thanks for your vote. Good luck, Sea Breeze
Monogram DISP480DXASS jack hammer noise behind the Climate Control Drawer.
By the way you discribe it, it sounds like it's going into defrost mode check and make sure freezer side isn't iced over or that the drain isn't iced over if it's a side by side drain should be at the very bottom of freezer side usually hidden behind a piece of plastic if it's a top and bottom the drain will in the freezer very back bottom also hidden hope this helps
Mar 04, 2016 | Refrigerators
WHIRLPOOL REFRIGERATOR FREEZER ON TOP FREEZER NOT STAYING COLD
there is a timer on the base that takes it thru a defrost mode, Turn it clockwise until it clicks then it will cycle in 30 minutes , do this about twice - it should clear the ice blocking the coil and get colder.
Dec 13, 2013 | Whirlpool Refrigerators
Model# 596-63822200 Bottom Freezer Refrigerator. Makes loud noise around 15 seconds every 5 to 10 minutes. Temperature is warm in refregirator and freezer. Naomi
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Kenmore 62232 / 62234 / 62239 Bottom...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
I have a Kenmore side-by-side frig which I was told was mfg by Whirpool: Model 106.51264104 Mfg April 2003 It stopped cooling on both sides. A repr tech replaced "RELAY CAPASITOR ASSY." I now get freezer...
Okay if not the coils inside the freezer section behind the panel that covers the coils is where the ice is located? I don't know of any other coils inside the freezer? Did you confirm that compressor itself is running? Not just the fan and clarify again the location of the ice.If you have frost on the freezer coil, you probably have a defrost problem. Your freezer should go into a defrost cycle about twice a day. When this happens the compressor and fans shut off and a defrost heater in the freezer coil will turn on heating away the ice. This usually last 10 - 20 minutes. If the defrost coil doesn't defrost it will become a solid block of ice and this will inturn block the air from blowing into your refrigerator compartment. There are several things that can go wrong with the defrost cycle such as the defrost timer, defrost heater, or the defrost termination thermostat.After defrosting the coils with a hair dryer, they have not frozen up again in several days. I did notice that the air diffuser in the refrigerator side does not seem to open by itself. It is not broken physically. If I open the luevers manually, eventually they will close and not reopen.
OR
Relays will burn out for the same reason a light buld burns out. So many hours of life and they go. Also a power surge from a storm can cause them to go.
If the compressor is cold try a relay. If you hear the compressor click on and then click off after 3-5 seconds try a relay.
Thank You
Jun 01, 2009 | Refrigerators
Evaporator coil in freezer red hot and water dripping on it.
This normal operation. Happens twice a day to defrost the freezer coils. Last about 20 minutes.
May 02, 2009 | Kenmore Freezers
Red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Aug 06, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Noisy F&P fridge freezer
Most of f&p make this noise its most annoying, but could also be ice buildup on the fan blades, creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
Jul 27, 2007 | Fisher and Paykel Active Smart E522B...
Amana AFD2535DES French Door Refrigerator Logo
212 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
