LOW VOLTAGES POWER SUPPLY
I'm servicing one colord tv ,the problem is low voltages instead of 190 volts i only got 70 volts on the horezontal output
  • 1 more comment
  • Anonymous Nov 07, 2007
    What should the +B voltage be for a Philips 25PT2252/79R TV be.
    I have 120 volts and a narrow picture.
    I have a Philips 25PT2252/79R TV.Narrow picture + B voltage 120 volts.
    Any clues
  • desmond cassisa Nov 07, 2007
    I have a Philips 25PT2252/79R TV. Narrow picture. +B voltage 120volts
    Any clues
  • 372 Answers
Hi. It will be easier to help you if you tell us the make & model of your tv set.
Posted on Sep 21, 2007
SOURCE:
Poor picture does not fill viewing area {small in the center
Check its main power supply board's output voltages. It sounds that the output voltages comes out of it is too low that it should be.
May 25, 2013 | Sony KDL55EX500 55 in. HD-Ready TV
Baird tv problems
First check its main power supply regualtor board's output voltages. If any of these multiple voltages become low than normal, this type of fault can occur. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 25, 2013 | Televison & Video
Hp computer tower will not go on
Would that be an LED (Light Emitting Diode), blinking on the back of the Power Supply?
If so, instead of being an LED that indicates the Power Supply has power to it, it has now turned into a diagnostic LED (Light), and is telling you the Power Supply is bad.
Do you have an economical multimeter, so I can guide you in testing the 3 low DC Voltages; that come out of the Power Supply?
An economical multimeter can be purchased for as little as $5 to $12.
I have seen them on checkout aisle racks, in major discount stores.
The dangerous high AC voltage, is kept contained within the metal case of the Power Supply.
(100 to 240 Volts depending on what country you are in)
The Power Supply is a Converter.
It converts the high AC voltage into 3 low DC Voltages;
3.3 Volts, 5 Volts, and 12 Volts.
In comparison two D cell flashlight batteries produce 3 Volts DC.
OR;
Use a KNOWN to be good, Compatible power supply; for a temporary test unit.
{"Honey, I'm going to borrow the Power Supply out of your computer.
I'll put it back when I'm done."
"What? I'll be sleeping on the couch? K"} (Lol!)
Also, is the inside of the computer dirty?
(Computer Unplugged from power, Anti-Static Procedures FOLLOWED)
Let's start here......
Also, what is the Product Number?
Back of computer tower, white Service Tag.
P/N = Product Number
Post back in a Comment.
Regards,
joecoolvette
Apr 09, 2013 | HP Pavilion Computers & Internet
Samsung LCD tv showing colored pin strip lines
It seems as the main power supply regulator boards' output voltages are low. Check it. Contact any experienced service technician. This work is not a user repairable one.
Jan 08, 2013 | Televison & Video
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
Faulty power supply
Faulty switching regulator, usually caused by dried out (aged) electrolytic capacitors. Sony part number for switching regulator is 1-413-987-11 but no longer available new from Sony - try to find a junked SVP5600 or SVO5800 (same sw reg) or you will have to try the capacitors. Make sure you use the correct types (power supply low impedance) and put them in the correct way around. ***warning - dangerous voltages - hazardous area - death or injury may result from contact with high voltages ***
Jul 30, 2012 | Sony SVP-5600 VHS/S-VHS playback VCR
To low output voltage 4.12 V pdp-121p
you power supply may be faulty or, or you motherboard, even try to update the bois
Oct 08, 2009 | Compaq 220W Power Supply for PDP-121P...
Olevia LT26HV LCD TV won't turn on
Olevia has problems with the power supplies. Best solution is to remove the back of the TV. On the 542 it is about twenty number 1 phillips head screws. locate the power supply connectors check the board for the voltages, clearly marked on the PCB. Continue to check the voltages by powering on the Television. all voltages should be within its described range. If a voltage is low or nonexistent, the power supply is bad, usually a bad capacitor.
There are three series of caps, on the low voltage side it is 16 volt, next 24 volt and finally 36 volt (these are just max ratings.
which ever power that was found low the cap would be near that voltage output connector.
next step is to remove the board and replace the capacitor, using a soldering iron and making sure to solder with no slop.
with the board on an insulated (nonconductive surface connect the board to the televion. Check voltages and if no other voltage issues reassemble.
Jul 30, 2009 | Olevia LT42HVi 42 in. LCD Television
Avr problem the voltage of horezontal out 70 volt
check the capacitor in power supply area, dry capacitor can cause this problem.
Jun 11, 2009 | Televison & Video
Will not turn on.
  • proceed as given after your power supply is ok (your statement)
  • isolate power supply from h/output stage.
  • check diodes & capacitors connected with flyback transformer.
  • check for print short.
  • ckeck h/output transistor.
  • connect supply to h/output stage.
  • put on the set.
  • hope this will help.
  • good luck
still there is a drop in voltage then your fly back transformer faulty.
Oct 12, 2007 | RCA F32450 32" TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Ekse
