Question about Dryers
Kenmore electric clothes dryer, front loading Model no. 110.64812200 Serial no. MP2815385 Type DWSRELE2406028CV54 The dryer runs fine. It just doesn't put out any heat. I will take it apart tomorrow. Is it a heating element, fuse, relay, or something else? Thanks in advance.
2 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: Dryer doesn't put out any heat, but it does run.
Check the schematic, it should be on the back of the machine. You'll see that the heat circuit probably goes thru the switch on the motor. Use a multimeter to check continuity thru the element, the heat sensors, and the timer. You can do most with the machine unplugged. If you're familiar with checking live circuits, just keep in mind that 220 comes from both ways and meets in the middle, where the load is: so be very careful.
Posted on Apr 21, 2009
My kenmore dryer 70s series wont start
send the model number,open the door and look around the opening where you put the clothes in,you'll see a tag with model and serial number,just need model number.
Mar 18, 2013 | Kenmore Dryers
Drum gap
what is the model number?
Dec 09, 2012 | Kenmore 83142 Electric Dryer
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
Clothes are getting caught and torn
yes. your drum gasket is bad
May 24, 2010 | Dryers
I think the moisture sensor is bad in my kenmore he4 electric dryer. It works well on timed dry but does not stay on when using the automatic settings. It is still heating fine, it just stops prematurely...
it is a problem with how you are loading the unit. you must use the same type and weight of clothes or the sensor will think the light items are dry and then shut the unit off.
try to do a load of all towels and see what happens on the automatic cycle. if it does well then you just need to sort your clothes better.
the sensor is just 2 metal strips and will never fail.
Mar 13, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Apr 21, 2009 | Kenmore Dryers
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Dryers Experts
