Question about Kodak EASYSHARE M1063 Digital Camera
Won't turn on after charging; lens just sticks out
I have had my M1063 Kodak Easyshare digital camera for three weeks. The battery died and the lens still sticks out. I charged it and now the camera won't fully turn on; it just blinks for a sec then shuts off again. The lens just sticks out.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Posted on May 15, 2009
Kodak M1063 lens will not open
It needs to go to shop like all the others. These are bad news.
Sep 18, 2012 | Kodak EasyShare One Digital Camera
My Kodak M1063 digital camera will not turn on no power at all
Kodak EASYSHARE M1063 Digital Camera My Kodak M1063 digital camera will... Answer my camera will not turn on no power at all.
Feb 13, 2010 | Kodak EASYSHARE M1063 Digital Camera
My camera wont turn on and lens stays out
are you using the battery that came from the box KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001
first charged the battery for 4hrs and make sure when you charge it theres a light indicator in the camera., you may also try to turn On the camera while its charging in a AC adaptor., If its did the same thing call kodak toll free 1 800 235 6325. it means the camera gear lens is already defective thats why your camera will not stay On
Oct 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera died while i was using it and now wont charge
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
The Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Oct 04, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
Aug 13, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Kodak easy share M1063 digital camera wont stay on
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
When i press the "on/off" button my camera turns on then off
This problem is frequently due to either weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
Jul 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Won't turn on
Keep holding the power up button on untill it oppens up the lens I mean and light up the disoplay.
I hope you did not dropped it to a hard surface.
Vitally
May 28, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens will not retract- will not go on oroff
Charge batery with 5 volt charger adapter , not usb.
Vitally
Apr 24, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
390 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
