Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Ok i have a kicker solo baric its a dual 2 omh speaker and the amp is an 2000 watt hifonics brutus also it has two voice coils
  • Dean
    Dean May 11, 2010
    whats your problem mate? you have only stated what you have?
3 Suggested Answers
  • 113 Answers
SOURCE: How to bridge two 15" kicker solo barics 2 ohm voice coil with a kicker zx750.1
put them in series.
Posted on Aug 09, 2007
  • 231 Answers
SOURCE: amp 4 a Kicker S17L7
just make sure your kenwood amp can at least handle a 2ohm stereo load.Most amps now are able to .Your amps manual should list this or go online and check for that model .You basically have 2 subs in one allowing you to use one sub box in stereo mode.And just hook it up like two speakers left and right ..make sure amp has a crossover so that you only get bass at your woofer
Posted on Jul 30, 2009
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
How do you hook up 2 12" L7's to a kicker 1200.1 amp?
You have a 2 ohm stable amp, and dual voice coil subs.. The L7's come in both Dual 4 ohm, and Dual 2 ohm, so you have to know what impedance your coils are prior to wiring. HERE is a nifty little guide that will show you how to wire your subs. DO NOT WIRE THE SUBS LOWER THAN 2 OHMS ON YOUR AMPLIFIER!
Aug 23, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Amp 4 a Kicker S17L7
Jul 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
What amp need to use for Kicker (2) S12L7 12in Solo Baric
you should use an amp with approx half the power of the speakers max output (i.e 1000 watt speaker use no more than 600 watt amp)
May 12, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
How to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Jan 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
General ?
they are dual 2 ohm all L7 are 2 voice coil per speaker so it is like 2 speakers not 1 the dual 2 ohm version is so you can use 2 speakers wired in series to get a 2 ohm load 2 ohms + 2 ohms = 4 ohms then parralel the 2 at the amp to cut it in half to get 2 ohms. I have full warranties on mine and i dont really sell alot of them any way I prefer the hifonics they sound better last alot longer and take way more power and put out 3 times as much sound. but i can check it out if you have the info.
Sep 17, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
159 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
