Question about ViewSonic N3252WS 32 in. LCD TV
No picture, sound works, but along with high-pitched noise
ViewSonic 32" N3252w - no picture, sound OK, but accompanies by a high-pictched screeching noise. What's the problem and how do i fix?
  • 1 more comment
  • ivanovajulia Apr 21, 2009
    source is cable box. i only have 1 additional cable plugged in (in addtion to the cable box cable), a tri-colored cable, yellow, red, white (i think), plugged into either the cable box or dvd player. I tried unplugging everything and leaving it unplugged all day, but it didn't help.
    from this website, this seems to be a common issue with this model of ViewSonic, but i'm unclear on what the fix is.
    thanks for the suggestion.
    this issue creeped up gradually. the TV was working fine for a long time, and recently, it would start to black out only on the left side. Then, the picture would go out entirely, the screen turning black for a few minutes, and then it would return. Next, the picture would go out, i would turn the TV off and on again, and the picture would return. Now it's at the point where there's no picture whatsoever. Maybe this adds to the description.
    thanks,
    julia
  • Paul Gallas
    Paul Gallas May 11, 2010
    What is plugged into the back? What source is being used (tv tuner, dvd, vcr, etc)
    Scholar:
  • 71 Answers
My guess is that you might have the yellow (video) cable plugged into an audio input on the TV. Make sure that the yellow cable is plugged into both the video out on the DVD player and the video in on the TV. Most of these connections are color coded.
As a diagnosis, try changing the TV input (using the remote) and let me know if you still get the buzzing on the other inputs. If no, then, it's most likely your RCA connections. If yes, it's another problem.
Posted on Apr 21, 2009
  • Paul Gallas
    Paul Gallas May 04, 2009
    This sounds like a bad power supply (transformer). The power supply is unable to provide enough power to accommodate a full picture. When the TV is turned off, and on, a jolt of power provides a picture, but then the same problem occurs. The buzzing is also a symptom of a bad power supply. Unfortunately, my technical expertise is not with repairing, only diagnosing. At least you'll have some idea of what is wrong when talking to the repair guy.
I have a 32 inch viewsonic model n3252w black screen with no sound .
This model has a history of power supply problems. Depending on your level of expertise on electronic repair, you can repair the power supply or replace it. The most common repair is to replace the bulging power supply capacitors.
Feb 26, 2013 | ViewSonic N3252w 32 in. LCD Television
Vizio 32 Inch, turn on completely fine for about 20-30 minutes. Then sound goes out accompanied by high pitch noise and picture has varying lines or colors through it. Won't power off, have to un
Are you a decent do it yourselfer? It sounds like it is the capacitors. What happens is they get hot and expand (the top of the Capacitor). The top will be dome shaped and it will look like the top is splitting open. You can buy (about $1.50 ea.) the capacitors at your local electronics store (not Radio Shack they usually don't have a high enough amp).
You will need to take the back off and look at all of the capacitors to see which ones are bad. Usually it will be 2 or 3 of the larger ones but there could be more. Next you will need a soldering iron with a fine tip and some wicking material. How could are you at soldering and de-soldering? before I go on.
If you let me know the model # of your set I can be a little more detailed also.
Sep 24, 2012 | Vizio L32 32 in. LCD HDTV
Viewsonic N3252W picture ok but no sound
Download the repair book to this TV by net. It will have all details.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
How to reboot N3252W
Unplug the power, wait an hour, then plug it back while holding the power button down. This will reset back to factory settings and most likely will solve your problem.
Mar 01, 2012 | ViewSonic N3252w 32 in. LCD Television
Viewsonic 32 inch lcd t.v screen lights up for about 10 seconds and then goes off everytime,.pwer light is on and so is the sound,. but no brightness at all,.
Are you going to DIY repair and have all the tools needed?
See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20N3252W/
You need to check the fuse and caps in the power supply and at the inverter board.
Please read more here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Oct 30, 2011 | ViewSonic N3252w 32 in. LCD Television
Tv stopped working watched night before next morning no picture or sound
Inspect the power supply module for any bad caps with domed tops first.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20N3250W/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Apr 01, 2011 | ViewSonic N3252w 32 in. LCD Television
My viewsonic n3252w made a pop sound then turned itself off, the tv is 3years old now. when i try to turn it on it tries then goes off again, if i unplug it for a while i get a picture then the same things...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
May 08, 2010 | ViewSonic N3252w 32 in. LCD Television
No Power - Viewsonic N3252w LCD TV
you go to a service centre near your area who repear it
Sep 08, 2009 | ViewSonic N3252w 32 in. LCD Television
My ViewSonic N3252 display is just a black screen in all inputs. Sound works fine but no picture.
As with most LCD screens the two most problems that cause black screen are bad a solderjoint on the inverter board or bulging capcitors, the next problem would be most likely the power mosfets witch break down after time.
Jul 28, 2009 | ViewSonic N3252w 32 in. LCD Television
ViewSonic N3252WS 32 in. LCD TV Logo
737 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
