Question about Cyberhome CH-DVD 300 DVD Player
Doesn't do anything now
The machine was manufactured September, 2004. Until recently it worked fine. Now it doesn't do anything. The green power light is on. The power switch does nothing, nor can I open the dvd tray. Since it is a cheap machine, do I just toss it, or is there something I can do?
  • angramspen Nov 09, 2007
    The red power light will not go to green??
  • Anonymous Mar 11, 2009
    my cyberhome CD-DVD 300 DVD player won't turn on. The LED light changes from orange to red to green, but that's all it will do.
  • 4 Answers
The CyberHome CH 300 is a good, inexpensive DVD player with a power supply board prone to fail, because of a few weak components, especially if left turned on and not used.
Usually, if the power supply fails, the red light will not illuminate when plugged in, and of course not turn green when turned on.
If you have this specific problem, I can repair the power supply for $20.00. Contact me at [email protected] to arrange shipping and return of the repaired board.
Posted on Nov 17, 2007
When i put the dvd in the machine it trys to read it but then it stops and there is a ? mark over the picture of the dvd in the top right corner. is there anything I can do
Posted on Mar 26, 2009
Same thing happened to mine. The warranty is long over, and it would cost too much to repair it. Just buy a new one.
Posted on Nov 04, 2007
~WHY IS NO ONE NNSWERING THESE PROBLEMS!!! ALL WE WANT IS HELP!! PLEASE EXPERTS ANSWER THESE PEOPLE'S PROBLEMS!!!I HAVE THE SAME PROBLEM I NEED TO KNOW!!!
Posted on Sep 27, 2007
Its a power supply issue cheap chinese product buy american or at lease Japanese
Posted on Nov 12, 2007
SOURCE:
Drink-o-matic seems to run fine but doesn't get cold
Power supply is getting weak, and or the room is way too hot.
Nov 10, 2012 | Sharper Image Drink-O-Matic
Dell dimesion wont turn on at all
So it doesn't power up at all? I'm only asking because you said it's not the connection.
If it doesn't power up, open the box and reseat everything, something may have come loose during the move.
Sep 21, 2012 | Dell Dimension 2400 PC Desktop
Following a printing job of more than two or three pages, both orange lights and both green lights come on. The printer then is not functional. There is no paper jam. If I turn it off, then back on, it...
I had this problem at work. We went from a PCL 6 driver to a Universal PCL 5 driver and it worked fine printing multiple pages. And has ever since. I would check your driver first and see if it can be updated. If so, update it and try again. If not or updating doesn't work, try a different driver, especially if you are using a PCL 6 on a 32-bit or an XP machine. Best of luck to you.
Aug 04, 2011 | HP LaserJet 4L Printer
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
Wireless connectivity is it possible on the EL1352G
Greetings - Looking at the specs of the machine at the E-Machines website it doesn't appear to have any internal slots for a WiFi card upgrade.
However, there are plenty of USB ports available and an inexpensive USB WiFi dongle ($15-20 USD) would work just fine. Doesn't matter which one, as long as it has drivers for Windows 7 (which would be any recent USB WiFi hardware).
Regards and thanks for using Fix Ya.
Mikeywaf
May 04, 2011 | eMachines EL1352G-01w (884483537679) PC...
Headlight not working fuse good bulb good no power to switch
i had the same same problem with my 1992 vulcan 750. more than likely it is your reserve lighting devive located on the right side battery box. have you had a problem with your regulator/rectifier lately or a power surge of some type?
May 19, 2009 | 1992 kawasaki VN 750 Vulcan
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
Cyberhome CH-DVD 300 DVD Player Logo
347 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
