Question about Gateway GTW-P42M102 Television
Remote does not work
Remote stopped working.
Model: BRC-241
It just stopped working, even the on off button does not work.
Bought a Harmony remote and even that does not work anything on TV
Bought another BRC remote and that does not work. Harmony people say it is the IR sensor on TV. Need to know how to replace the IR sensor I think. Can anybody help me define the problem and or repair TV?
3 Suggested Answers
SOURCE: Remote Control Sensor
u have to rape ur mom and then shuv it uo her ***** k? did that help. if youre thinking im joking then im not bvecause the juice from the fanny rehydrates the remote and make it hyperacvtive and gives it the strength to work one again. and... i like girls :)!
Posted on May 12, 2008
  • 3 Answers
SOURCE: gateway grw-p42m203
See http://www.fixya.com/support/t315924-gateway_plasma_tv for symptons, cause and fix...
J
Posted on Jan 10, 2009
Logitech harmony 650 remote doesn't work with old Roku player
I have an old Roku and was able to get the harmony 650 to recognise it. The model of my old Roku was SD since I originally used it on my analog TV. Everything seems to work without having to "teach" the Harmony. The only quirk was having to use the Exit button to go back to a Netflix movie description and again to go back to the channel list.
Jan 15, 2012 | Logitech Harmony 650 Remote Control
My harmony 520 simply stopped working.
Have you tried resetting your Logitech Harmony 520 remote by updating your remote's firmware? Firmware replacement fixes several Harmony problems.
To upgrade or reapply the firmware on your Harmony remote:
  1. Launch the Harmony remote software and log into your account.
  2. Click on the Downloads button at the top-right corner of your screen.
  3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote.
  4. Once the firmware upgrade is complete, click on the Update Remote button.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Apr 10, 2010 | Logitech Harmony 1000 LCD Touchscreen...
My devices suddenly stopped responding to my remote even though the remote looks to be working normally
Remove batteries, let it sit for a minuit then put in some fresh batteries.
Still not working?
Plug it back into your computer and load Harmony Remote software. Click on "update remote" this will reload the firmware and programming.
I've had a couple harmony remotes go wackey on me but normally re-loading the programming or putting in fresh batteries fixes em right up!
Cheers,
Kevin
Feb 01, 2010 | Logitech Harmony 670 LCD Remote Control
My 550 remote stopped working. The light under "activities" goes on, the bastteries are good, but nothing else works. Please help!
Please try re-installing the firmware.
1. Log into the Logitech Harmony Remote Software on your computer
5. Test your remote.
Jan 24, 2010 | Logitech Harmony 550 Remote Control
Down Button Doesn't Work
map the button that dosnt work to the LCD.
do a firmware upgrade, update the remote.
if you can use the button with no issue from the LCD, its a hardware issue, e-mail tech support.
button mapping to LCD, this is for 1000 but it applies to all remotes
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9185
firmware steps:
Jan 03, 2010 | Logitech Harmony 676 LCD Remote Control
Harmony 550 remote - buttons not working
Hey!
Unfortunately most things you need to do would require access to the Harmony Remote Software. However, the only advise I would have is for you to remove the batteries and try putting them back in.
Sorry I couldnt be more helpful...
-Kennedy
Dec 25, 2009 | Logitech Harmony 550 Remote Control
My remote for the harmony 550 says welcome to remote even after I replaced old batteries with brand new batteries. No buttons will work any suggestions?
First I would check to see if any of your buttons are sticking. I have found that this is a common problem with the 550 remote. I really like this remote but if nothing works check your buttons to see if any are pressed under the plastic. This remote can only work one button at a time so if one is being pressed it will not work.
Dec 10, 2009 | Logitech Harmony 550 Remote Control
My Harmony 890 turns everything on and off, but when I am in PVR it just suddenly stopped letting me use any of the buttons (ie, menu, guide, channel, volumn). what do I do
I would hook the harmony back up to your computer and the update the remote. If that does not fix the problem then I would down load the firmware and then update your remote. If you still have problems I would check your check your buttons in the program. You can do this by logging onto your Harmony account, select the Activities tab and press on the “customize buttons” under the activity you are trying to fix. Scroll down to the menu exit info buttons and see if there assigned to the correct device and correct command. If none of this works I would see if the menu button works in another activity like Watch TV or Watch DVD.. If the menu button does not work in another activity then the remote may be broke. If it does work then I would try the original remote with your DVR and see if that works. If that works then I would manually teach the harmony remote. Harmony calls this “Learn command” It’s a button in the lower right corner while in the “customize button” tab.. If none of this works then pull out your 45 and put a hole in it.
Hope this helps
Nov 28, 2009 | Logitech Harmony 890 LCD Remote Control
My logitech harmony 890's creen stopped working
1- Remove the battery from the Harmony Remote for 10 seconds and insert it back in, and test the remote to see if the screen is displayed properly. If this does not fix the issue, please proceed with the following steps.
2- Make sure you have the latest Logitech Harmony Software (version 7.6.0) installed on your computer.
3- Connect your Harmony Remote to the computer. Run the Logitech Harmony Remote software on the computer and Login to your account.
4- Click on the "Downloads" button at the top and select "Firmware"
5- Remote will go through the firmware update, which will put the Harmony Remote back to Factory Default with the most updated firmware. Then software will ask you to select "Yes" to update the remote and click on "Next" to do a remote update, which will take the information on your account with your Devices and Activities and bring them into the Harmony Remote.
6- If this Firmware Update process does not fix the LCD screen issue, try doing a Firmware Update in "Safe Mode". To do this; remove the battery from the remote, press and hold the "Off" button on the top of the Harmony Remote and insert the battery back in to the Harmony Remote. Screen will display "Safe Mode" and then please follow the steps 3 through 5 again.
if this does not work, please try.
if this doesnt work, i suggest that you e-mail logitech from their website to get further assistance.
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Phone number:
Street:
City/Town:
Country:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
please make sure that you tell them you have tried a firmware update.
Feb 22, 2009 | Logitech Harmony 890 Universal Remote
Open Questions:
Televison & Video Logo
73 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
