Question about Kenmore Dryers
Dryer doesn't put out any heat, but it does run.
Kenmore household front loading clothes dryer
Model no. 110.64812200
Serial no. MP2815385
Type DWSRELE2406028CV54
This dryer runs fine, but just doesn't put out any heat. Any answers or suggestions. I'm going to open it up and look at it tomorrow. What should I be looking for? Is it a heating element, fuse, relay, etc.?
Thanks in advance.
    Genius:
  • 1,198 Answers
Check the schematic, it should be on the back of the machine. You'll see that the heat circuit probably goes thru the switch on the motor. Use a multimeter to check continuity thru the element, the heat sensors, and the timer. You can do most with the machine unplugged. If you're familiar with checking live circuits, just keep in mind that 220 comes from both ways and meets in the middle, where the load is: so be very careful.
Posted on Apr 21, 2009
My LG front loading dryer doesn't dry well
Check the exhaust vent when running and be sure there is a good flow of air. You may have to clean the exhaust pipes all the way through. Dryers require a good flow of air for proper operation.
Jan 10, 2012 | LG Dryers
Kenmore dryer will only work on no heat cycle...any other heat cycle will give pf code. md number 417.84092500
The Kenmore H5T is an electric clothes dryer meant for residential use and manufactured by the Kenmore Company, which manufactures a wide variety of appliances for the home, including refrigerators, dishwashers, microwaves, stoves, and clothes washers and dryers. While most Kenmore clothes dryers work well with only basic care and maintenance, certain problems, such as the dryer not heating, occasionally occur. Troubleshooting this issue may solve the problem without the help of a service technician.
instruction
  • Ensure that the dryer is properly connected to a working grounded power supply. Confirm that the power cord is plugged firmly into the dryer and the power outlet. Reset household fuses or circuit breakers if necessary.
  • 2 Remove the lint screen from the bottom front of the dryer. Pull off all lint so that the filter screen is clean, and replace the lint screen in the dryer.
  • Run the dryer for 5 minutes on a normal cycle and hold your hand under the outside exhaust hood to feel for air movement. If there is no air movement, turn off the dryer and unplug the unit. Disconnect the exhaust vent and clean out any possible obstructions, such as excess lint. Reconnect and confirm that the vent is not kinked or crushed and preventing proper heated air flow.
  • Ensure the dryer is not in a room or outside with ambient temperatures below 45 degrees Fahrenheit. The dryer will be unable to heat properly if the ambient temperature is too low.
  • Avoid overloading the dryer with too many clothes, which will limit proper heat and air flow in the dryer. Make sure the dryer is not set on an "Air Only" dry cycle, which does not provide heat.
  • Contact an authorized service technician if the preceding steps do not resolve the problem.
  • Dec 20, 2010 | Kenmore Dryers
    Kenmore Stackable washer/dryer Model #11088752793, won't heat
    Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
    Best wishes,
    Graemevm
    Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
    10 year old kenmore model 110 gas dryer drum turns but will not dry clothes
    I have a Kenmore Model 110.74612200 it came with the house and needs another service call-not heating- how old is this model? Wondering if it might be time to buy a new one. Dryer has seen a lot of use in the past 5 years from a household of six.
    Feb 21, 2010 | Kenmore 63942 Dryer
    LG TROMM Front Load Dryer / Not drying clothes
    check the vent or condensor depending on what type of dryer.
    Sep 28, 2009 | Dryers
    Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
    what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
    Jun 02, 2009 | Kenmore Dryers
    Kenmore Dryer not heating
    thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
    Mar 09, 2009 | Dryers
    No heat in kenmore 97273100 72731 front load gas cloths dryer
    check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
    Nov 02, 2008 | Kenmore 73952 Gas Dryer
    Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
    Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
    Jul 15, 2008 | Roper REX4634KQ Electric Dryer
    Dryers Logo
    160 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
