Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
My wd-73727 turns on, but nothing on the screen.
Power comes on, light stays green, but no pic or anything at all on screen. I have read several posts about light engine problems, but no one seems to describe what a light engine problem would look like. Does my problem sound like a light engine problem??
  • 6 more comments
  • Dennis Russell Apr 21, 2009
    I have the lamp out, and it looks fine. When I turn on the tv I hear it running. I just got disconnected with an "expert" that I paid 20.00 to chat with with no answers, how do I get him back, do you know if I will be charged?
    no, I hear a click, and then possibly the fan, but doesn't start and stop.
  • Dennis Russell Apr 22, 2009
    Hey, I think you are on the right track. I put the bulb back in and now I am hearing the arcing sound three times and then nothing. I pulled it back out again, and put it back in and then got sound, but no pic.
    Really, so am I understanding that the arcing sound is the Light Engine working?
  • Dennis Russell Apr 23, 2009
    Crikett, I would like to discuss this more with you if possible.
    Thanks,
    Djrhemi345
    Thanks for your response. I am going to replace the lamp, but I think that I may still have a light engine problem after that. I received this tv from someone who did not want to deal with it, so either way it is a good deal. I know a great shop that will rebuild my light engine rather than replacing the whole assembly, so if I still have an issue after replacing the lamp, I may go that route. One thing I am curious about is that my service manual says that my replacement bulb is part number 915P027010, and the bulb that is in the set is 915P0270A10. I have looked at them both on the internet, and they look to be the same other than the A in the part number. Do you know what the difference is?
    Ya,everything that I have researched says the same. The sticker that has the A is actuall on the housing, but the website below shows both part numbers on the lamps only, and all the specs seem to be the same. I tend to agree with you, sue the bulb that the manuals say, I just wonder if the guy I got this set from tried to replace the bulb, and put the wrong bulb in. Even your website says the 915P027010. Would that cause the bulb not to fire?
    http://www.purelandsupply.com/Mitsubishi...
  • Dennis Russell Apr 24, 2009
    Thanks for all of your help. I found a lamp on e-bay for 89.00, but it is just the lamp, no housing. Will I be able to put the 915P027010 in the housing that I have even though it is the 915P0270A10? They appear to be the same size, wattage, etc. Do you think this will be a problem?
    President:
  • Mitsubishi Master
  • 1,779 Answers
Each case is different. With you behind the set I would like someone there to turn the set on and you will listen for what will sound like an arcing sound, usually about three tries, then nothing. That will tell you that the inverter is working to ignite the lamp but the lamp says no. In that case you need to take the 6x6 cover off and remove the lamp and look at it. Some shatter and that's an obvious sign of lamp failure. If you do not hear the inverter then we can suspect the color wheel which is part of the Light Engine. Only will you see a light engines failure is when a polarizer goes bad and discolors your picture. Other than that you can't tell other than trouble shooting. So let's try the lamp way first.
Posted on Apr 21, 2009
  • 4 more comments
  • Jim Krause Apr 21, 2009
    You will have to contact customer service for that. As far as the set goes I don't want you to be confused with the fan running, the sound I am referring to sounds totally different. Does it sound like it is starting then stopping and repeating that cycle?
  • Jim Krause Apr 22, 2009
    Replace the Lamp ! The arcing sound is the ballast trying to start a bad lamp. Let me know.....
  • Jim Krause Apr 23, 2009
    The lamp supply is doing it's thing to ignite the lamp, but if the lamp does not light, the lamp is bad. Like I said lamps won't always show physical signs of damage in order to be bad. I would suggest replacing the lamp. The light engine is the entire assembly after the lamp. The light passed trough a tunnel and a digital light processor receives the light, processes each color and away we go. The light engine usually cost about $800.00 for the entire assembly minus the lamp. One thing you must remember in the future, try not having any DLP set on during a storm when you think you might have a power outage. This can play HELL with the lamp because the fan cannot cool down the lamp like is normally done. It dramatically decreases it's life. That also goes for rolling black-outs in the summer.
    Let me know if this helps you.
    My parts supplier has your model with lamp # 915P027010-----only. I do not know where the A comes into play. If I had your set in my shop I would use the number above. If you would like to check it, go to Encompassparts.com
    Sometimes they sell just the lamp, and not the housing, but they don't show just the lamp, it comes complete in the housing.
  • Jim Krause Apr 24, 2009
    Yes it can. We've had them already.
    Everything should be OK. Please : When you get the lamp use a small amount of rubbing alcohol on the face of the lamp until dry then DO NOT touch the face again. The oil from your skin can cause the lamp to prematurely fail because of the high heat. God Bless and Good Luck !
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
No Power to light on WD-73727...
This cable attaches to the lamp,reach in behind the lamp case in the tv and hold it in place and reinsert the lamp make sure it plugs into the lamp securely.
Aug 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi wd-73727 have new lamp bulb;did not
Your Light Engine needs replaced. Usually around $600.00-$850.00
Jul 11, 2009 | Televison & Video
PSPwon't turn onGreen light will come on while chargingbut no pic
your battery is probably totally dead try and get a secondary battery for your psp and see if it works
Apr 28, 2009 | Sony PlayStation Portable (PSP) Console
Mitsubishi WD-73727 will turn on, light is green, but no picture whatsoever. Nothing. I have tried the reset, and same thing.
try this push menu and input for 5 seconds. this wll cause the lights ussally a number of times pause then flash another for example flash 1 time pause then twice this is a 12 code... which by the way means no errors been recorded this will help me determine what area to troubleshoot
Apr 21, 2009 | Mitsubishi WD73727 73" HDTV
Nds lite not working
Youve damaged the top screen cable - nothing to do with wifi block
see www.dsdoctor.co.uk
Jan 31, 2009 | Nintendo DS Lite Console
No picture on TV with powerlight on
If you press the power button *on* your TV (rather than using the RC), does the power light still stay on red rather than turn green?
Jan 05, 2008 | Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
389 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
