Question about Acer Aspire 3003WLMi Notebook
Acer Aspire 3003Nwlmi - Want to upgrade the processor,hard drive,graphics and also want to know what is the motherboard. If i can upgrade, how/what would be the processors/hardrive and graphics. let me know till the latest i can go..
Show video card Aspire 1691
I concur with Chris about this laptop model, (NOT that Chris needs me to concur)
If I may;
For the Aspire 1690 series of Notebook PC's, the graphics chipset is soldered directly to the motherboard.
There are models of laptops that DO indeed have a separate graphics, or video card. They use the MXM technology.
The Acer Aspire 1691wlmi Notebook PC, may have either the ATI Mobility Radeon X600 GPU, or the ATI Mobility Radeon X700 GPU.
(Graphics Processing Unit, or also known as the graphics chipset)
This is one example of the ATI Mobility Radeon X600 graphics chipset,
http://www.ebay.com/itm/1x-ATI-Mobility-Radeon-X600-216PDAGA23F-BGA-Chipset-/280796092668?pt=LH_DefaultDomain_0&hash=item4160c058fc
You are looking at a Top View, as it is mounted on the motherboard.
What you do not see is the method of mounting.
This graphics chipset is mounted to the motherboard, via a BGA surface mount.
Ball Grid Array.
To explain the BGA surface mount;
Compare to an older Intel Pentium 4 desktop processor, that uses a Socket 478 processor socket,
The processor has contact pins on the bottom of it's circuit board. 478 of 'em.
The processor socket has matching socket holes. (478),
http://en.wikipedia.org/wiki/Socket_478
With a BGA surface mount there are no contact pins, on the bottom of the graphics chipset, as used on an older Intel Pentium 4 processor. (That uses a Socket 478 processor socket)
There are no socket holes in a processor socket.
No socket on the motherboard.
In place of the contact pins, there are Solder Balls on the bottom of the graphics chipset.
In place of the socket holes in a socket on the motherboard, there are instead Copper Pads.
(The copper pads are also gold plated)
The graphics chipset is set down on the motherboard, with the Solder Balls lining up on the Copper Pads.
Heat is then applied at a specific temperature, and length of time.
This action melts the solder balls, and solders the graphics chipset to the copper pads.
(Thereby also soldering the graphics chipset TO the motherboard)
This example of one maker, of a SMT/BGA Rework Station at work, will help demonstrate the above method,
http://www.ersa.com/art-ir-pl-650-346-1472.html
Scroll the page down, click on the red -
Take a few minutes to view the IR 650 demo video
That's just the mechanical aspects of replacing/upgrading a GPU, using a BGA surface mount.
Now you need to look into what will work.
The motherboard chipset determines what hardware components, can be used on a motherboard.
The motherboard chipset, as used on the Acer Aspire 1690 series of Notebook PC's, uses a Northbridge chip, and a Southbridge chip.
(Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Integrated Circuit, or chipset, that is used for graphics, is the graphics chipset, or G.P.U.,
http://en.wikipedia.org/wiki/GPU )
The Northbridge chip handles the faster capabilities of a computer.
Handles the Processor, Ram Memory, and High-speed graphics.
A graphics chipset using the PCI bus is NOT high-speed graphics.
(Such as a PCI graphics card inserted into a PCI slot, on a desktop computer motherboard)
Integrated graphics is also Not high-speed graphics.
High-speed graphics uses an AGP bus, or a PCI-Express bus.
The ATI Mobility Radeon X600, and X700 graphics chipset, on the Acer Aspire 1690 series of Notebook PC's, uses a PCI Express x16 bus,
http://en.wikipedia.org/wiki/Comparison_of_AMD_graphics_processing_units#Mobility_Radeon_X300.2C_X600.2C_X700.2C_X800_Series
IF, your Aspire 1690 series Notebook PC, uses an ATI Mobility Radeon X600 graphics chipset, and you wanted to upgrade to an ATI Mobility Radeon X700 graphics chipset, it would not be worth your trouble.
By the time you buy the X700 chipset, have the X600 removed, and X700 installed, it would be cheaper, and wiser to just buy a better laptop.
[ One I bought for work to use on Electronic Technical Manual's, is an Acer Aspire 5552-3691
1) AMD Athlon II X2 P340 (Dual Core) processor
2) 4GB of DDR3 Sdram (SO-DIMM) ram memory at 1066MHz
3) ATI Mobility Radeon HD 4250 graphics chipset.
Price? $398.00USD.
Not the best by FAR. But MUCH better than what you have presently.
Just food for thought ]
Just thought you would like to know why, it isn't feasible to try to upgrade the graphics chipset.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 06, 2012 | Acer Aspire 1691WLMi PC Notebook
I have acer travelmate 2355nxc with 40 gb hdd. want to know how to increase its speed and capacity.
Hi, how are you?
To upgrade your laptop, you will have to verify the capacity for upgrade of your laptop.
The Acer Travelmate comes with:
  • Intel Celeron-M 360 Processor 1.4GHz
  • 256MB DDR SDRAM -
  • 40GB Hard Drive
  • DVD/CD-RW Combo Drive - To read DVDs and CDs and write CDs
  • 15" XGA TFT Screen
  • Intel 852GM 64MB shared graphics
  • Operating System: Windows XP Home Edition
  • Based on this information, you can upgrade your memory depending on what type of memory your motherboard supports and how many empty slots for memory does your laptop have.
    The hard drive can be upgraded also depending on which hard drives does the BIOS will recognize.
    I will suggest to contact ACER and ask for the options and upgrades capacity.
    God Bless You!!!
    Hope it helps.
    Remember to rate solutions, to keep fixya.com working for you!!
    Feb 21, 2011 | Acer Computers & Internet
    I cont play 3d games graphic card is there in acer aspire 4720z
    * The system configuration of Acer Aspire 4720Z PC Notebook is :
    160 GB or larger hard disk drive / 5-in-1 card reader / 512 MB or 1GB DDR2 533 MHz DIMM module / Intel Pentium dual-core mobile processor technology T2310 (1 MB L2 cache, 1.46, 533 MHz FSB), Mobile Intel GL960 Express Graphics Chipset.
    * Your system have "Mobile Intel GL960 Express Graphics Chipset" graphics accelerator card embedded in the motherboard. Like most of the laptops/notebooks, there is no room for upgrading the graphics card in the motherboard!
    * But you can upgrade the RAM upto 2 GB using two DDR2 DIMM memory modules.
    * If you want to play 3D games with better performance, switch to Windows XP SP2 and upgrade the RAM!
    * If you want to upgrade the memory (RAM), you can check this site : http://www.laptoppartsexpert.com/c-60093-acer-aspire-4720-series-as4720z.html
    please rate this advice if it helps
    Nov 17, 2010 | Acer Aspire 4720 Notebook
    I would like to upgrade my Acer Aspire 4315 PC Notebook it has celeron processor 1.73ghz 533mhz fsb 2.53gb ram running on win xp pro what dual core processor can this laptop take?
    Well most modern laptops cannot not be upgraded in this manner because the processors are hard soldered on the motherboards. Even if you have a removable type processor the newer dual cores will not be compatible with your type of motherboard.
    May 29, 2010 | Acer Aspire 4315 Notebook
    How do I find my graphics card on acer laptop 4720z and change settings to best play games
    please rate this advice if it helps...tc! :)
    Jan 13, 2010 | Acer Aspire 4720 Notebook
    Upgrade Acer Aspire m1100
    Is you are going to do a complete overhaul, you are better off going with a ASUS motherboard, with a processor, and 4 GB of memory. Here is a good place to get all these parts and your computer will run REALLY great.
    www.computershopper.com
    Feb 08, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
    Upgrade processer
    the price you will pay for a processor, motherboard and hard drive, will cost more than a newer notebook, thats if you ever get it to work again!
    Sep 08, 2008 | Acer Aspire 5315 Notebook
    Upgrading my laptop's processor to a lower processor
    No laptops graphics are integrated into the motherboard and cannot be change with any bit of ease
    Aug 10, 2008 | Acer Aspire 5100 Notebook
    Acer aspire 3680
    You do not have a "graphics card" in this laptop. There is a hard-wired graphics processor chip on the motherboard. Check your owners manual and you will find it listed. I don't have mine with me or could look it up for you. The short answer is that you cannot upgrade the graphic card.
    Oct 09, 2007 | Acer Aspire 3680 Laptop
    Acer Aspire 3003WLMi Notebook Logo
    189 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
