Question about Water Heaters
Water heater runs. Heats water. No hot water at the faucet.
  • erickg
    erickg May 11, 2010
    ok hot water heaters work off of pressure. they are pressurized from the cold water coming in and that is what pushes the hot water out to your faucet. it is heating water? how to tell if its not coming out?gas or electric?
    President:
  • 2,692 Answers
Do you have water at that faucet on the hot side? What if you run it a long time? All hot faucets or just one? Which one. The one farest from the heater?
Posted on Apr 21, 2009
Why is there no hot water?
Check the heating elements for continuity.
Feb 13, 2016 | Water Water Heaters
Had it installed yesterday, but it heats water for approx 15 seconds then switches off then heats up then cold and so on. Any help appreciated
Is this a tankless water heater??
Gas or electric??
Incoming water may be too cold for thermostat setting.
Gas pipe might be undersized, or wires too small depending on power source.
Call the manufacturer and the installer.
If this is tank heater, then check if tank is hot, but hot never arrives at faucet... caused by bad faucet cartridge
http://waterheatertimer.org/Crossover.html
Gene
Mar 05, 2015 | Water Water Heaters
I have a Cantebury park model with an electronic ignition
What water pressure reading do you have? IS there a mixer in the system? What is the exact model number?
May 02, 2013 | RTO Water Heaters
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
Our gas water heater (Rheem Optima Quick recovery 81 series) heats the water as evidenced by the steaming water we can release from the temperature and pressure relief valve but we get no hot water from...
Sounds like a plumbing problem.
Since no tap gets hot water, chances are good the problem lies in the hot water pipes between the water heater to the first Tee.
Look for sediment lodged in water heater hot water pipe.
Or sediment lodged in elbow or Tee.
Other problems can be in play.
Faulty check valve or mixing valve if these are installed.
Faulty recirculation system if this is installed.
Also crossover at single-handled faucet where the cartridge is bad and lets the cold water flow into hot water pipe whenever another faucet is turned on. If you are getting cold water out the hot tap, and you know the hot water heater has hot water, then crossover is suspect > in addition to sediment blockage at hot water heater.
Upvote the help.
For a price, expert works with you while you work on timer or any do-it-yourself project.
May 15, 2011 | Rheem Water Heaters
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
Cold water runs through the faucet shower but no water at all through hot water side
If no hot water at any faucet, and your sure water in water heater is hot, check by-pass at back of tank for wrong positioning.
Jun 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot water heats up when heating only is on
Is this a tankless heater?If so it will only heat when the water is turn on.It take a minute or two to get hot water to a faucet.
Mar 18, 2009 | Bosch Water Heaters
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
