Question about Zenith SY2772DT TV
My tv will only display ch. 2 my little 5 yr. old was playing with the settings it is a 15 yr. old zenith tv
    Scholar:
  • 71 Answers
Depending on your market, it sounds like all of the other analogue channels have been terminated (not your son's fault) in order to provide stronger HD signals. You may need to run to wallmart and get that $50 decoder box.
Posted on Apr 21, 2009
I have a one for 3 in 1 remote URC-3030B04 and the
search on google for ONEFORALLCODES.PDF
download the fill and look for zenith
scroll down there are many zenith codes
Aug 27, 2014 | Televison & Video
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
29agm2 how to access the servise menu
Hello
Check these proceedings and find out which porocess works with your Sharp TV.
* Unplug the TV
* Press and hold the {VOL -} & {CH+} buttons.
* While holding the above buttons, plug in the TV.
* The TV will turn on with the Service Menu displayed.
* There are 5 category menus:
Deflection - Signal - Feature - Fix Value - EEPROM
* Use {CH+} {CH -} buttons to select a category.
Note: Not all models will have 5 categories.
Some will jump to 'Signal' category.
* Use {VOL+} to enter the category.
* Use {CH+} {CH -} buttons to select the item to be adjusted.
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
LCD TVs :
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
Mar 22, 2011 | Sharp 29AGM2 29" TV
What is my sharp code
Hello
To get into the service menu do the following.
Unplug the TV
LCD TVs :
After entering to the service manu, goto V-Chip options and Unlock it. You have to reset all V-Chip options after resetting it. OK.
Dec 19, 2010 | Sharp 32C-240 32" TV
My old zenith (probably early 90s) only gets up to channel 48 when there are more channels provided by my cable service. I have used the autosearch, and thats what number it goes to.
[1] use LG exteanel setup box chenal convater 90 to 200 ch avalabel in market .
[2] use inside of tv extra chenal convater pcb. PHLIPS.
[3] change complet new tv chasis with new latest function and all new facilety
EXP.
UOC Technologey chasis
NTSC /PAL /SCAME / AUTO Multi Colour System
Auto Search tunig
A/v 1 -2 -3 Stereo.
A.v Out facility
DVD Comonent input
surround sound mode
1300w pmpo woofer System
on timer /off timer /clock /sleep timer facilety
calender
5 pictur mode
Curtain Effect.
all facilety Avalabel in TOSIBA /SANYO chesis
pls Cont. your Nr.tv techicien
Oct 30, 2009 | Zenith C27A24T 27" TV
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
2002 zenith console television
If you lost the remote for a zenith television and want play a movie on an input, use the channel up/down buttons to navigate. Ususally if your on ch 2, press the down button. Line 1/2 will appear on a blackscreen if the device is off. Otherwise, I have had great success using a GE universal remote with my Zenith tv/vcr combo unit. (by the way, I work for the technical support department for my city's local cable company)
Aug 12, 2008 | Televison & Video
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
No remote - can't get tv off of aux mode
most zeniths change just the channel up or down takes if off video/aux. Its usually below channel 2. otherwise need remote
Jan 08, 2008 | Zenith C13A05LG 13" TV
Televison & Video Logo
135 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
