Question about Nintendo DS Lite Console
I formated my 4gb SDHC card and now the computer doesn't recognise it.. what have i done, is it useless now?
Be sure to format the 4G cards as FAT32 with default partition size. Hope this works for you.
Posted on Apr 21, 2009
My computer wont format my micro sd card
Is it an SD card or a microSD card? If it's a 4GB (or larger) card then it's neither, but instead an SDHC or a microSDHC.
If the card is an SDHC/microSDHC then your card reader may be only SD-compatible. If this is the case then you can buy an SDHC-compatible card reader and use that. Alternatively, if you want to use this card with some other device, such as a camera or a phone, format the card in that device instead of in your computer.
Jul 10, 2012 | SanDisk 4gb Class 4 Sdhc Sd Hc Flash...
Sigma 4in1 card reader not working
Try a different / all other USB ports on the computer, and if possible, a different computer if no USB port on your computer works with it. If it still doesn't see the drive, the drive is probably not working. If it does see the device, but is asking for drivers, provide a disk with drivers that came with the reader - or check the Sigma web site for drivers that work with you OS (Windows, Mac, etc.), download and install / extract.
If it sees the device, but doesn't see the memory card, the reader may not recognize the newer, larger capacity memory cards. SD cards are smaller than 4GB in capacity, and SDHC cards are 4GB and larger. Make sure that if you're trying to read an SDHC card that the reader SPECIFICALLY says it works with SDHC cards. Most SD readers can NOT be upgraded with firmware to be able to read SDHC cards - a new SDHC reader is required.
Jan 30, 2012 | Cameras
Canon legria fs306 will not recognise the 4gb sdhc card i put into it, but recognises the 2gb sd card, when it should register both! need to use sdhc, how can i fix this?
You haven't stated the make and model of SDHC card; it's not unknown for cards to become faulty or even for cheaper no-name brands to be re-labelled factory reject.
Make sure that the lock switch on the edge of the card is fully unlocked, and if that doesn't work try it in another SDHC compliant device. If that fails then you have a faulty SDHC card which must be replaced. Otherwise it's the camera which is at fault. There have not been any firmware updates, so the only option would then be to return the camera to a Canon Service Centre. Depending upon when you bought it, the repair might be under warranty.
Aug 05, 2011 | Cameras
My IPAC hx2790b will not recognise my 4gb sd card
PCM, Backup the data on the card to a computer. Format the card. Try on your iPAC. If still not recognized. the format in a different computer. Try on your iPAC. Repeat the process till it is recognized by your phone. When and if you get fed up of trying, throw the card away as useless/unusable.
Jul 04, 2011 | HP iPAQ hx2790 Pocket PC
It will not format a 4gb SanDisk SD card
Your 4GB card is actually an SDHC card. The DX6490 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards 2GB and smaller.
Nov 28, 2010 | Kodak EasyShare DX6490 Digital Camera
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Nintendo DS Lite Console Logo
61 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
