Question about Casio Exilim EX-S880 Digital Camera
Power button stucked
The power button is stucked. How can I "lift" the button up?
Presumably it got wet, or was something else involved like glue, sand, coffee, etc. Make sure the batteries work, since power is required. You might try a small drop of vinegar, which might be enough to eat through any sticky substance. give it 15 min, and try again.
Posted on Apr 21, 2009
Cd stuck in sterio aparently there is a reset button to push and release cd.were is the button?
I'm not aware of any button on car cd units. Usually when a cd is stuck in the unit, you need to take another cd, open the door and gently lift or pry up the stuck cd to release it.
Dec 04, 2016 | Car Audio & Video
Rear lift gate lock stuck in the closed position
use a round bar under the lock tongue and pull it back as you press the button to open the latch
Jan 06, 2014 | 2008 Chevrolet Uplander
Power liftgate will not open with remote, instrument panel control or button in rear cargo on lincoln mkx
It can be faulty switch or its issue with lift gate latch.Its got stuck up hard or cracked inside.It has to be inspected.-----------
There are few help links with proper solutions for these problem.I suggest you to refer the links.
Click the link below:----
2007 Mercury Mountaineer: Liftgate will not Unlock or Open? http://whoisbyme.blogspot.in/2012/06/2007-mercury-mountaineer-liftgate-will.html
Adjust Hydraulic Lifters? http://schematicsdiagram.blogspot.in/2012/04/adjust-hydraulic-lifters.html
How to open rear lift gate? http://repairhelpcenter.blogspot.com/2011/12/how-to-open-rear-lift-gate.html
--------- Power Liftgate Shuts Down http://whoisbyme.blogspot.in/2012/07/power-liftgate-shuts-down.html
------------ Power Lift Gate Will Not Remain Open http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-remain-open.html
----------- Power Lift-gate will not Operate http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-operate.html
------------- Liftgate will Not Stay Up Open? http://whoisbyme.blogspot.in/2012/07/liftgate-will-not-stay-up-open.html
---------------- Rear Door will not open http://whoisbyme.blogspot.in/2012/07/rear-door-will-not-open.html
------------ 2000 Toyota Corolla: Rear Door wont open from outside or inside? http://whatisbyme.blogspot.in/2012/05/2000-toyota-corolla-rear-door-wont-open.html
These details will help.
Thanks.
Nov 25, 2012 | 2007 Lincoln MKX AWD
GFDN240ELOWW
My husband just fix my GE Dryer GFDN240WW "Start Button broke" issue. Here is what he did; He removed the control knob to access the phillp screw. Unscrewed screw and lift up on control to remove panel and unhook power supply. Then set control panel on face. Unscrewed 5 larger screws to removed black plastic panel w/ mother board attached. Set board aside and located power button which was broke off. Compare button to all other buttons on panel to see how they are attached to panel. My husband used Plumbers Goop from Lowes store to attached power button like the others. Then he reassembled the dryer and presto! It works!
Jun 09, 2012 | GE Dryers
Power button is pushed in to the camera It is stuck or broken there
Hello, The button maybe stuck in the grew, try this very very carefully
  • Take a small pin and insert it in the gap between the button and the housing, then tilt the pin and slowly try to lift it up.
the button may come up loose and fall, which means the switch is broken. press and see whether it works.
if you got your warranty you may get it fixed for free :)
Mar 30, 2011 | Sony Cyber-shot DSC-S600 Digital Camera
After changing the bellow on a whirlpool duet, I have no power to the unit and the power button is stuck down. Not sure if there is a switch that is not activated when the control panel was put back on?
If the power button is stuck I would say it was damaged while you were replacing the boot or something is not lined up correctly behind the console face. Unfortunately that power button is not just an individual switch. It is part of the user interface.
I would remove the top lid 3-4 screws at the back top and lift up and pull back. and see what I could see from there.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
2002 Dodge Grand Caravan - Power Liftgate Stuck Open
Check all the fuses under the hood and under the dash. Then try having someone wiggle the liftgate while you "tap" the down button repeatedly. Do not apply too much force to the liftgate.
Aug 29, 2009 | 2003 Dodge Caravan
WILL NOT TURN OFF
Pry off the face by lifting from the garmin name at the top of your unit. If unit is on, press the RESET button.
Jul 25, 2008 | Garmin StreetPilot C330 GPS Receiver
Button stuck in kenmore 110
may try pusing up on drum but best bet remove front ..remove 2 screws under filter ..press clips in at front corners lift top remove screws each side of front panel let panel lean forward button should fall out if not lift panel up and remove completely
Jul 21, 2008 | Kenmore Dryers
Casio Exilim EX-S880 Digital Camera Logo
161 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
