Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Whats the best settings for a 2 ohm solo baric 15
Whats the best settings for a 2 ohm solo baric 15 inch sub i have only one
  • blueextc3221
    blueextc3221 May 11, 2010
    please elaborate - settings on what?
    Dual 2 ohm or single 2 ohm voicecoil?
    what amplifier are you using?
    Problem Solver:
  • 6 Answers
Settings are all about what amp and box u got. tell what setting your talking about.
Posted on Jul 02, 2009
Best way to hook up a 15" solo baric L7 to a2400w cx 1200.1 kicker amp
The CX1200.1 amp is 2 ohm stable. Hopefully, you have the 4 ohm DVC version of the Solo-Baric L7. If so, connect the DVCs in parallel (both positives together, both negatives together) to the amp. This will maximize the output power of the amp. If you have the 2 ohm DVC version of the Solo-Baric L7, the best you can do is connect the DVCs in series to the amp. This will cut the output power in half, though.
Oct 30, 2015 | Kicker Car Audio & Video
I have 2 solo baric l7 duel 4ohm subs and a legacy la-2499 amp.What is the best way to wire it up?
Unfortunately, the amp is only 2 ohm stable, so the best option is to connect each subs voice coils in parallel (2 ohms) and connect the subs in series (4 ohms).
Oct 06, 2015 | Legacy Car Audio & Video
I have one solo baric hooked up in a 4 ohm series to a 1000 watt kenwood amp that I've tried hooked up normal and bridged at 4 ohm. When I turn it up the sub cuts out. I've looked up a bunch of...
hello, first i would find out what ohm your sub is cause you may think your setting it up for 4 ohm you may be going 2 ohm or 8 ohm. here is the link to for wiring solo baric. http://kicker.com/wiring_diagrams
Aug 24, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Ihave 2 kiker 15 inch solo l5 1500 max 750 rms so what kind power , how many chanal am.p i need ? im confused......
If they are 2 ohms I would recommend dropping to 1 ohm for maxium out put. To drop to 1 ohm you are going to run the 2positives and 2negitives together in either a bridged or monoblock 1500w amp. After doing so i would get the spects for the speakers freq. ect. or go to a quality audio store and most of them will help tweek it for free. I would recommend Kicker ZX1500.1amp for best compatiblity.
Nov 07, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Solobaric subs l7 15-inch
this should help you
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Jan 23, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
344 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
