Question about Motorola Mobility L6 Cellular Phone
As i open my phone it display an insert sim
L6i
  • 3 Answers
Try taking the battery out, and turning the phone back on, it a boot won't work, please open the back of your phone, and take the battry out and make sure the sim card is plugged in correctly.. which phone company do u have?
Posted on Apr 21, 2009
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Security code of motorola L6i
Motorola L6i Solution.
download the fullflash from this link
https://rs27l32.rapidshare.com/#!download'27tl4'19708271'R3443H1_G_0A.64.19R_PDS001_LP0015_DRM0201_JPJAVA_G_0A_L6_03_00_20R_GSVL6iT678DR03C_1FF.rar'12071'R~389A241D1C262AC27865CC592E190002'0'0
download rsd lite from here
https://rs35l3.rapidshare.com/#!download'35dt'21012706'RSD_LITE_3_5.rar'5835'R~0'0'0
install the rsd lite on your pc and extract the firmware you downloaded with winrar or winzip, remove and insert battery again, press *+#+power all at the same time, you phone should enter flash mode, conect to pc and open rsd, click browse and select the file you extracted, click start and wait till process completes and phone reboots. all will be ok. Note: all data will be lost.
Nov 09, 2011 | Motorola Mobility L6I Cellular Phone
How to open gprs on l6i?thanks.
HERE'S WHAT YOU'VE GOT TO DO:
1. Make sure that your phone supports MMS and GPRS.
2. Click your SIM card, then click GPRS.
3. Your service provider will then send you a configuration setting.
4. As soon as you receive it, save it.
Or, you can directly call the Customer Service Department of your Network Provider and ask for a configuration setting for your GPRS.
Thanks. I hope it helps...
Jul 23, 2011 | Motorola Mobility L6I Cellular Phone
My phone asking insert sim?
Hi,when a phone displays insert Sim, it means that the phone's Sim tray where Sim card are inserted in bad and can't make the Sim card display again .You'll need to replace Sim tray.
Take care.
Jul 07, 2010 | Samsung Star GT-S5233 Cell Phone
My Motorola L6i phone's program seems not functioning well. i can't send SMS co'z it can't access to network. help me
Try to insert any other sim and check whether you are able to connect to network .IF not then there might be problem with the network line. If you are able to connect to any network then check in message option whether it is line 1 or line 2 configured. If it is line 2 change it to line 1 and check
Dec 29, 2009 | Motorola Mobility L6I Cellular Phone
We insert sim card in cellphone, even though the cell phone dispaly "please insert sim card"
It seems that your cell phone is having trouble reading the SIM card. You have two options. First you can attempt to clean the SIM contacts on your device. To do this simply apply a small amount of alcohol to a Q-tip and gently rub over the gold contacts where the sim card normally goes, this will help to remove any dirt build up and provide a better connection. Second, contact your service provider and request a new SIM card. Sometimes SIM cards can go bad similar to a memory card failing. A new SIM card maybe all you need.
Nov 24, 2009 | Motorola Mobility L6I Cellular Phone
Sim card in . but comming up insert sim
If it still showing insert sim, you can get a rubber eraser and erase the sim's chip. Also rub eraser on the part of the phone where sim is inserted.
Try to insert other sim cards if it is showing the same error. If yes, then you need to clean that part of the phone where sim is inserted. Try the rubber eraser technique. If it does not work, have a soft earbud cotton and dip in alcohol then gently rub it on that part.
Sep 01, 2009 | Motorola Mobility L6I Cellular Phone
My motorola L6i shuts down by it's own,when I try to make a call.
Possible Virus, Most likely the SIM needs upgrading again. If able try Master Rest.
Jul 01, 2009 | Motorola Mobility L6I Cellular Phone
My motorola l6i getting hang and restarting offen
i hav a motorola L6i set of 2006...some time...it becomes struck or hang...i hav given it for service many times..thay changed thier key pad,bubble pad etc...they told me to change it and buy a new one...i hav spent more than 500 rs for repairing it...still it automatically sometimes get hang...is it worth to keep it...or buy a new one???or d problem can b solved??
Apr 04, 2009 | Motorola Mobility L6I Cellular Phone
Unlocking procedure
I think you need to insert the original Sim card that was used when you set the code.  The code is stored in the card. Once you have done that and unlocked the phone, the phone will work with all other Sim cards.  Just remember if you set the code you have to use the card that was in use at the time.
You can take the phone to a shop and they might be able to clear it.  They have special software for that purpose, that isn't readily available to all.
Oct 31, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
