Question about Kenmore Washing Machines
The washer driving belt breaks.
Kenmore Laundry Center - Models 96802/06804. The washer driving belt breaks, leaving a strong smell of burned rubber. I have chaged the belt 3 times. The problem does not go away. Plesae advise,
Juan Santana
  • Anonymous Mar 30, 2014
    lat9400aaw, model
  • 537 Answers
Sounds like a spin bearing might be bad:
Check this link:
http://www.fixya.com/support/t197849-burning_smell_screeching_sound_but
Posted on Apr 21, 2009
My Beko washing machine has a smell of melted rubber and I found black bits on the drum. None of the clothes have been damaged but they do smell a bit. Is it overheating or something?
hi Alyson.
this is what i found on the internet.
WHAT'S CAUSING A BURNING SMELL IN YOUR WASHING MACHINE? If you notice a burning smell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The Burning Belt Smell Many top loaders are direct drive. This means they do not use a belt. The motor is directly connected to the transmission.
In Whirlpool and Kenmore models there is a rubber coupler between the motor and transmission that takes much abuse. It's very common for the fingers or the rubber itself on the coupler to break. A clicking noise with no spin or agitation along with a slight rubber smell are symptoms of this problem.?DIY repair is possible. Older models may also have belts that can be tighted or replaced
The new Whirlpool or Maytag washer can often be fixed without calling for repair.
To work on a top load HE washer pull the empty unit away from the wall. Drape a small rug or towel over the control to minimize damage to the wall and the panel. Lean the unit against the wall and the bottom will be clearly visible. Lie on the floor and note if there are rubber pieces or shavings under the washer. The belt may be rubbing against a plastic guard attached to the motor. The solution is actually quite simple: If the belt is shredded or worn you need to replace it. You can call a repair person or, if your washer is under warranty, the manufacturer. Or, if you or someone you know is handy, you can do it yourself!
Electrical Problems If your washer smells. The first thing to do if you notice an electrical smell in your washing machine and not a rubber burning smell, is to unplug the machine and call the manufacturer or a repair person.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
or go to this link might help you to find out more.
washing machine has smell of melted rubber and found black bits on the...
Nov 29, 2017 | Beko Washing Machines
Battery light on and a strong burnin rubber smell
SOUND LIKE ALTERNATOR SHAFT BEARING FAILING CAUSING ALTERNATOR PULLEY LOCK OR PUT DRAG ON DRIVE BELT CAUSING BURN RUBBER SMELL OR DRIVE BELT LOOSE CAUSES BELT SLIPPAGE MAKE BELT RUB AND BURN.WHEN YOU SMELL RUBBER BELT BURN SMELL WATCH OUT DRIVE IS GOING TO BREAK.
Aug 04, 2011 | 1983 Ford Fairmont
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
Other Causes
Nov 07, 2010 | EuroTech Washing Machines
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Tub not spinning smell rubber
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Some part of the motor burned out that's why you can smell burning rubber. Check some faulty parts.
Mar 28, 2010 | Maytag Washing Machines
It does not drain at all? and it makes a weird noise and it smells like burning rubber how do i fix it? some one told me that it might be the pump.
Mar 27, 2010 | Maytag MAV2755AWW Dependable Clean Top...
Burning rubber smell
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Jan 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite Front Load - smell of burning rubber while in use
I've never had a smell problem like this before, but I have had the rubber lining to the door "shred", leaving eraser shavings all over the laundry. This happened with my first HE3t and I complained at SEARS and they just sent out a brand new replacement. About a month or two later, the same thing happened. I had SEARS come out and replace that rubber seal, and haven't had a problem since.
Although I can't answer on the smell, I highly suggest you keep an eye out for shavings on your laundry. Also, with the door open, at the bottom you can pull back the rubber seal slightly and expose the drain to be sure nothing is clogged or getting caught in there.
Oct 10, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
136 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
