Question about Amana ALW480DA Top Load Washer
How to replace belt??
I've just purchased a new belt for the ALW480DAW front loader, but, it seems to be so much slack on the new belt. I can't find where to slip the belt on too. There seems to be one big "wheel", underneath the drum, but, when I put the belt around there is still too much slack. I can't seem to find another pulley to slip the belt around. Also should the drum be able to turn with no belt on??. Not too sure what the problem is, but, am hoping it is only the belt. Old belt "melted" during a lockup when washing.
  • mrg1987 Dec 20, 2007
    how do I replace the belt on my amana washer
  • Anonymous Mar 18, 2008
    just can't find the other wheel for belt.
There are two wheels unplug every thing and turn upside down you will find the other wheel
Posted on Oct 02, 2007
SOURCE:
1986 cadillac fleetwood power steering belt
Below are 2 diagrams. Replace the bolts you've removed. Rotate existing belt counter clockwise to disengage the belt tensioner. Once it releases, you should be able to remove the old belt and replace it (using the diagram below). Once you start the car, the belt tensioner will automatically take up the slack.
1986 Fleetwood
Nov 04, 2011 | Cars & Trucks
I have a 13 year old Neptune MAH3000AWW. I've done the wax motor/circuit board fix a couple of years back satisfactorily. Now I have a sound that sounds to me to be a slipping belt noise. Is this a...
No its not hard to replace the belt at all..just remove back access panel and roll the belt off of the main pulley..place the new belt onto the motor pulley and roll it onto the main pulley..the whole job should take about 10 minutes and 5 of that is getting the tools out
GENE
This video is for a different brand front loader belt replacemant but the process is exactly the same
http://www.youtube.com/user/RepairClinic?v=a8jRgOn1wGY&feature=pyv&ad=8842436861&kw=belt
Aug 27, 2011 | Maytag Neptune Washer
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
I used the following links:
http://www.partselect.com/ModelFrames.aspx?ModelID=29693&ModelNum=ALW480DAW&mfgModelNum=PALW480DAW&ManufactureID=1&Selected=31971&Position=7&mfg=Maytag&Type=&Mark=7
http://www.applianceaid.com/amana-wash.html#belt
Oct 21, 2009 | Amana ALW480DA Top Load Washer
Installation of new serpentine belt on 2002 Chevy Cavalier
Use a 3/8" socket end to rotate the tensioner counter clockwise. It may seem stiff, but that's a good thing... you want the tension to be there. After it's off the tensioner the belt will pretty much just come out of place and off the other pulleys. ***make sure you orientate the belt as it was originally (ac or w/ ac)...diagram should be on the front shroud.
Oct 08, 2009 | 2000 Chevrolet Cavalier
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Amana ALW480DAW washer
Remove the front panel by loosening the two screws that hold it in place. Unhook the spring that puts tension on the tension pulley. Remove old/worn belt and replace with new belt. Very important that you use the correct size belt or the motor may be damaged and remember to hook the spring back for the tension pulley. The new belt has to go around the inside of the tension pulley.
Oct 22, 2007 | Amana ALW480DA Top Load Washer
Amana ALW480DA Top Load Washer Logo
739 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
