Question about Robert Yick Co. RanRYC168 Gas Kitchen Range
GE gas stove XL44
OO1-Oven will not turn on. Could it be a clogged line or electronic card gone bad? OO2-Where to find two alum burners give yellow flame due to corrosion hole bottom part? Thanks
  • 3 more comments
  • homecook Nov 09, 2007
    Burners work fine, but the oven does not want to heat up. The broiler works and the oven heats up in clean mode, but not for any set temp.
  • chaso Dec 11, 2007
    After using the clean feature, the oven will not work. When a temperature set the clean light flashes but the oven won't come on. GE XL44
  • Anonymous Jan 17, 2008
    Sealed burners work fine. Broiler comes on. Oven won't come on.
  • Robbie Z May 04, 2008
    Stove top works, and Broiler works, but oven will not come on.
  • Fission Sep 11, 2008
    Sorry, disregard the solution, I have the same problem.
Robert,
I had the same problem on a17 year old XL44. Oven would't come on because the Igniter was burnt, found one for $30 from an appliance dealer at a local flea market, it now works fine. Two of the four burners also have corrosion which disrup air mixture giving yellow flame that blacken wife's pots and pans. Standard Appliance Parts will special order but rather expensive, $44 for the one small in the back or $49 for any of the three larger burners. Trying to patch holes but cant find a 400 degree plastic putty. Will try home remedy of one part portland cement plus six parts lime, same formula been using for years to build fireplace, hope it takes on the slick aluminum. Thanks from South Texas, Santiago
Posted on Sep 11, 2008
I have the same exact problem with my XL44, any ideas? Time to buy a new stove? If I do, no more GE for me!
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Feb 26, 2009 | GE JGRP17 Gas Single Oven
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Robert Yick Co. RanRYC168 Gas Kitchen Range Logo
457 people viewed this question
Top Robert Yick Co. Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Robert Yick Co. Kitchen Range Expert? Answer questions, earn points and help others
