Question about Home
Replace inside stem on hot water Eljer shower faucet
Unfortuneatly I have 20+ yr old Eljer shower faucets. The hot water faucet leaks a steady stream of hot water. I found out that Eljer has been bought out by American Standard, and ordeed the center stems from their Pittsburgh PA home wherehouse where they still keep some Eljer parts. The problem is this: Eljer made it impossible to quickly remove the faucet knobs. There is a collar/ring accessed through a small slot on the outside of the stem near the knob, but when this ring is depressed through the small slot, nothing happens. The knob on the faucet still cannot be removed and the inside parts replaced. It is no wonder Eljer went out of business. I cannot find ANY company that services or has any information whatsoever on how to take apart an Eljer faucet. Please help me replace the inside stem unit for both the hot and cold shower faucets.
    President:
  • 1,489 Answers
Sounds like you might need a gear puller -- hardware stores would have them -- or auto parts.
Spray with contact cleaner wd-40 first, then install puller, depress ring and crank away at the puller.
Posted on Apr 21, 2009
How to install a danco 10472 4z-24h/c hot & cold faucet stem
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Feb 09, 2014 | Danco Faucet Stem
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
I have a Sterling tub & shower faucet that is about 25 years old that is leaking. I have replaced the seats & stems but it still continues to leak a small steady stream out of the tub spout. The...
Your fixture body may be corroded beyond repair. Since you've replaced all the rebuildable parts, I'd suggest you get a plumber to check it but expect that you'll need to replace the faucet. Get a modern "cartridge" (Delta, Moen or Kohler) fixture that can be easily repaired indefinitely.
Oct 28, 2017 | Sterling Plumbing
We replaced the cartridge of our one handle shower faucet and now the spigot leaks a steady stream of water
wrong stem.. the body of cartridge where the o ring seats into the body of the faucet needs to go all the way down.. try looking at new ong very carefully because they are almost identical except for this
Sep 02, 2010 | Danco Faucet Cartridge
Water leaks from my cold water and hot water shower handles (separate) whether the water is on or not. How can I fix this?
turn the water off! at the meter and go buy a faucet seat removal tool its L shaped with square heads on each end also buy a faucet valve socket to remove the faucet stems after you take the knobs and unscrew the trim housings once you unscrew the faucets stems there inside the hole deep is 2 brass seats that you need to remove and change put the new seats in and replace the washers on the stems and reassemble
Jan 20, 2010 | Home
Water comes out the shower head without the faucet lever being engaged
the whole faucet is bad it has an internal leak replace the whole thing
Jul 03, 2009 | Home
Low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Apr 05, 2009 | Delta & Single Handle Shower Faucet
There is a thin stream of water coming out from under the shower handle of my washer-type faucet whether the shower is on or off. What is the problem and how can I fix this please?
Turn off the water, remove the handle, escuchion, and stem.
Replace all washers/O-rings. If it is a plastic stem, replace the stem.
The seals are worn, allowing water to pass by.
On some really old valves, the actual metal walls of the valve eventually get worn, and washer replacement does not completely solve the problem, or last long. In that event, replacing the valve is about the only option.
Jan 19, 2009 | Moen 2919 Chateau Two Handle Tub and...
Shower diverter problem
It is very possible that a piece of rubber from the old washer or some debris has found its way into the shower diverter or the showerhead. The first thing to try, is to take off the showerhead and see if you get water without it. If you get water then your problem is solved!!! Puchase a new showerhead or take apart the old one and soak it in CLR or Lime-Away to clean it. If that doesn't do the trick than, Turn off your water supply to hot and cold. Remove the diverter (if possible) and inspect for debris. If you want you can also take out the hot and cold stems for a total inspection of the inside of the faucet. You can then flush out the inside of the faucet cavity with a Turkey Baster or something to that effect. Put it all back together ( use a bit of vasaline on all the rubber washers so they do not get stressed when re-installing) and you should be able to take a shower.....Also, if it was a cartridge you replaced, you may have inserted it 180 degrees opposite......Hope this helps.....Joe
Jan 12, 2009 | Ace Hardware BRASSCRAFT 45458 "ACE"...
Home Logo
1,230 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
