Beginning dump of physical memory
My computer is always beginning dump of physical memory. it shows a blue screen with requirement on remove new hardware, recent installment, or do the safe mode,.... in the end, is below information: technical information stop 0x0000007A (oxco7c1720, oxcooooooE, oxF82E450c, oxo6o8E86o) atapi sys - address F82e45oc base at F82D7000, datestamp 47e26e98 beginning dump of physical memory. hope to get your solution as soon as possible
    Problem Solver:
  • 8 Answers
This could be pretty complex. The ATAPI.SYS file controls the Hard Drive and CD-Rom Drive. I would recommend reading this MS TechNet article:
http://support.microsoft.com/kb/822051/ The article says that it's not uncommon for the problem to be caused by faulty memory or by problems in the mass storage controller subsystem, which makes sense since atapi.sys (a mass storage controller system file) is noted.
If you have multiple memory cards in the machine, it might not be a bad idea to take one out and try again. If the fails, keep swapping out memory cards until we either solve the problem, or elimite that as a cause.
Posted on Apr 22, 2009
Blue screen physical memory dump?
This is called the Blue Screen of Death or BSoD, this usually happen if u plug in or insert any new hardware. If u have recently added any new hardware, try it out, after plugging off the newly inserted hardware.
Jul 28, 2010 | Microsoft Windows XP Professional With...
Computer restarting again and again and shows a blue screen with "Beginning dump of physical memory." Also when i scan the system using kaspersky internet security antivirus it got restarted and i couldn't...
sometimes it happen because you have installed a driver recently and it is creating a havoc there. try to run in safe mode and restore the configuration to the previous one.
other options, is that a memory went bad. try to read what error is telling before the beginning dump of physical memory.
if one bank of memory is bad, try running your computer with one of the banks at the time.
Apr 23, 2010 | Microsoft Windows XP Professional With...
Physical memory dump
Hmm... Well a Bluescreen is when your computer crashes, and (as you have found out) preforms a physical memory dump. This can be caused by multiple things. Such as bad drivers, PFN(page frame number) or problems with your memory. When a bluescreen event occurs, the is a technical information which has an error code that can be used to help find the problem. In order to fix this problem, you may have to remove any software, or hardware that you have recently installed. To uninstall software, you may need to boot in safe mode, which is where your computer starts up using the minimal amount of drivers needed, in order to try to prevent the computer from crashing.
Here are some useful websites (sorry, my hyperlink icon isn't working):
  • www.datarecovery.com.sg/data_recovery/hard_disk_symptons_blue_screen.htm
  • www.maximumpc.com/article/features/blue_screen_survival_guide
Feb 27, 2010 | Dell Dimension 8400 PC Desktop
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Laptop starts dumping memory
Please run a system restore to factory settings.
May 14, 2009 | HP Compaq nx7010 Notebook
Windows program shut down Laptop problem model-no-XPS M1530
As with any blue screen, this is an operating system error in which a driver or program has overstepped it's boundries by writing into an unauthorized section of the memroy, therefore causing the memory dump. You will need to run a system repiar or reload with your recovery disc or operating system disc in order to cure the problem. Start with the repair, if the rogue still persists, then you will need to wipe the hard drive and reload the operating system.
Jul 13, 2008 | Dell Inspiron 6000 Notebook
Computer on the blink
this is the'blue screen of death..the Dell model is usually on a tag somewhere on back. supply that, and perhaps you can gain assistance here(I'm Dell Certified going back in time, by the way)
May 08, 2008 | Dell Dimension 3000 PC Desktop
Game troubleshooting
Hi. memory dumps like that are mostly always hardware (or drivers) related. If you haven't changed any drivers recently then it's probably hardware. My recommendation would be : 1) In the startup option of Windows (right click My Computer, advanced), disabled the automatic reboot upon memory dump
2) Next time you have a blue screen , identify the DLL or SYS file in the message. if it's always the same element that crashes then you found your problem. Google the driver name and see what is the problem. If you see almost random DLL or SYS files in your blue screen then you have an overheating issue (90% of the time it's the reason) or a simple hardware failure. (pain in the a** but these things happen) also, that doesn't mean the data is gone, but chances are if you can't boot at all ever again with the laptop you'll have to hook it's drive as a slave on another computer and get your data back. BUT keep in mind that the problem you are describing is NOT a HD issue or you would get the typical "NO HDD detected" or "No bootable OS found" post post-test issue. hope that helps !
Feb 22, 2008 | Computers & Internet
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
345 people viewed this question
David Payne
David Payne
