Question about Tomtom GO GPS Receiver
I have a tom tom go 710 and need to know how to reset it, and when i turn it on, the screen shows that I need to install SD card. I am wondering if I need the SD card for it to work properly?
  • 39 Answers
To reset your TomTomGo710 device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
tomtom go710 map data is on SD card without it, it will not work.
Posted on Apr 21, 2009
Unlocking my tom tom go 740
Posted on Aug 23, 2009
Is a 8gb sd card ok for my tom tom go710
I understand that the largest memory card that can be used in the 710 is only 2gb -
BUT it has to be an SD card not an SDHD card, otherwise it won't work!!
Hope this helps
Jul 07, 2012 | Tomtom GO 710 Car GPS Receiver
TRIED TO UPDATE MY TOMTOM GO 710 BUT NOT ENOUGH MEMORY BOUGHT NEW CARD BUT TOM TOM WONT TAKE IT TRANSFERED DATA BACK ON TO OLD CARD BUT TOMTOM WONT TAKE THIS...SHOW TWO CROSSED HAND ON MEMORY CARD...
Just had the same problem..............
I discovered that you must only use an SD card and not an SDHD card.
I bought a bigger SD card (2Gig), installed it and copied the data I wanted without any probs. With the SDHD card I couldn't transfer anything and didn't get any help as to why...(there's a lot to be said for trial & error).
Hope this helps
Jun 09, 2011 | Tomtom GO 710 Car GPS Receiver
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
I HAVE A TOM TTOM GO 710...DOES IT NEED A SIM CARD
yes, the tomtom 710 needs the sd card which has the maps on it. if you just bought it and didnt get one with it, i suggest you take it back, because the cost of the card often out weights the value of the gps.
if you want to buy a sd card for it, you can get one HERE on the tomtom site or you might want to try ebay.com which sometimes they have them...i just checked ebay for you and currently there are none listed.
Dec 16, 2009 | Tomtom ONE GPS Receiver
When turning on the no maps appears on screen
If you have an SD card installed then
Remove the SD card from the tomtom
The card may need to be formatted properly first or re-formatted.
Formatting is better done in a card reader.
There are differing views but this method has always worked for me.
Insert the card in the reader,. Using my computer or windows explorer right click on it and select format
select FAT32 as the files system
Now connect the tomtom to the pc but don't let tomtom home run.
Exit TomTom Home if need be.
You now need to select your tom tom which will also show as a drive and may even show its own special icon.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card.
DO NOT USE CUT AND PASTE !
Once all the files are on your new card switch off the tom tom and insert the sd card and re-boot the TomTom
It should now work.
If not try the hard re-set in which you would use a paperclip to reset the tomtom. there should be a tiny hole on the underside of the unti.
push the paperclip in there (not too hard) while the unit is switched on
This would cause a reset to factory defaults (you may have to set home location etc)
You may also have to switch off and re-boot again for it to take effect.
Aug 28, 2009 | Tomtom One XL GPS Receiver
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom GO GPS Receiver Logo
786 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
