Question about Sony KP-51WS500 51" Rear Projection Television
Replaced 2 IC's, (1) 5 amp fico fuse, (2) 3.5 amp fico fuse
Picture is still 3D type. So I went back and tested all fuses again and found that brand new 3.5 amp fico fuse was blown. I replaced again with new one, still fuse blows. What could be the problem?
  • gaurang46 Apr 22, 2009
    Yes, I replaced (1) 5 amp fico fuse on Board G and (2) 3.5 amp fuse on Board D. I tested all 5 amp fuse, 3.5 amp fuse, and resistors again to check they are not blown out. All fuses and resistors are fine. When I turn on TV, stand by timer light blinks 6 times. Picture is still 3D.
  • Sony Master
  • 8,617 Answers
Did you check the two 5 amp IC links on the G board.
Posted on Apr 22, 2009
I have a mitsubishi ws-65809. I relpaced the STK392-570 ICs and turned on the tv and it powered on for 2 secs and went off. I ran the test and got a 2 and 2 blink. Then ran test and got a 1 and 2 blin
If you unplugged the set you will get the 1,2 no error found, the 2,2 is short protection, I hope you had that before the chips were replaced, it is one or both of the pico fuses bad that protect those chips.
see photo of board, locations are 9FAo4 and o5 on the middle board where the chips are but further back.
12_15_2012_1_52_39_pm.jpg they are both five amp pico fuses.
Dec 15, 2012 | Mitsubishi WS-65809 65" Rear Projection...
I have a 2004 Chevy Cavalier. A couple of months ago, just after starting the car one day, the 'check engine' and 'trac off' lights both came on. I immediately shut off the car, waited approximately 5...
Many cars have the cooling fan on a thermostat or time delay, to allow it to run for a short period of time after the engine turns off, to cool the engine off. You may have just never noticed it before. So I wouldn't worry about that.
Your real problem is the blowing fuses, apparently you have a short somewhere in your wiring. Putting in bigger and bigger fuses is a great way to set fire to your wiring harness. It's possible that the wire is pinched or chafed somewhere, and perhaps when you hit a bump just right, it touches and shorts.
You may have to take this to the Chevy dealer or a GOOD independent shop to have them chase it down. Unless someone out there knows exactly what this is, it could be a tough one to find.
Apr 26, 2011 | Chevrolet Cavalier Cars & Trucks
WS-55909 convergence problem turns now into F9A04 Fuse issue
I had this happen on my WS55909 about 2 years ago. I dont remember what the circuit id's for the fuses were, but out of 6 fuses on the middle board, the two in the middle were blown. I traced the circuit schematic and found that only the convergence IC could cause these fuses to blow. It sounds like you already put in a new convergence IC (the one with the big-*** heat-sink which probably also needs a fan) but you need to make sure all those fuses on that board are still good. After I replaced that IC, my TV still didn't work. I went and double checked for continuity of all the fuses on that board and one was blown (after checking all of them and replacing the IC). Replaced it and the TV has worked ever since. Total repair cost was 23 bucks. Professionals recommended that I would be better off just buying a LCD TV than fixing my rear projection TV, but I still dont think you can get one of those as big as 55" for only 23 bucks! ****. BTW, mitsubishi would probably tell you otherwise, but you don't have to use those "littlefuse" fuses. I soldered in a fuse-holder for a glass fuse of the same value (5amp 125v in my case) that can be purchased at radio shack. A fuse is a fuse. My TV never burst into flames.
Apr 06, 2010 | Mitsubishi VS-50501 50" Rear Projection...
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Sep 30, 2009 | Zenith P42W46X 42 in. Plasma EDTV
I have a 2001 dodge durango, no blinkers
Do you have a tow hitch? The harness for the tow hitch might be rubbed through & shorting on metal. Use a test light & see if there's a short in the socket. Touch ground to a vehicle ground & it shouldn't light. Let me know if that helps.
Jun 21, 2009 | 2001 Dodge Durango
3D image
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 23, 2008 | Toshiba 43H70 43" Rear Projection...
Follow up on "no power to my tv"
3d picture ...sounds like to me a convergence amp issue...what type of tv is this?
Dec 01, 2007 | Televison & Video
Blown 4 amp fuse twice
ok appaloosa! is the fuse blowned again? if blow you have fault unregulated power section, you have defective parts like.. leak degausing or defective diodes or capacitor and or regulator IC. 2nd. defective horizontal output. if not blow the fuse u have fault oscillation!
Sep 14, 2007 | Pioneer SD-P55A3-K 55" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
199 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
