Screen flashes on for a second, first says no signal, then flashes input analog next and then goes off
Monitor comes on for just a second...first says no signal, then flashes back on a second time and says "input analog....can u help please?
  • 2 more comments
  • rkel78 Apr 21, 2009
    yes. the computer boots up properly, it's like the monitor is having problems staying on....i am not very computer saavy, so i really don't know if that tells you anything...when the second time it flashes on only for a second, you can see the normal desktop in the background....with a small block in the middle on top of the desktop screen that says "input:analog"..and then it flashes off again...you can make it start over by pressing the input button on the right side of the monitor...
    i wouldn't know where to begin on that one.....not sure about the video card...
  • Art Ellison
    Art Ellison May 11, 2010
    I'm thinking that you probably have a video card problem or a display problem.
    Since you say you don't have much computer experience, we need to look at a couple of things.
    Can you start the computer in safe mode? You do this by pressing the F8 key when starting. Can't tell you exactly when to do it, but I normally tell my clients that as soon as they see any white printing on the monitor, start tapping on the F8 key. If your computer starts in safe mode, we can do a better job of troubleshooting.
    If you cannot get it to stay on in safe mode, can you get into the BIOS settings (like pressing Esc or F2 or whatever your computer tells you to do to enter Setup?
  • Art Ellison
    Explain a little more-does this happen when you start up the computer? When you turn on the computer, does it really start up? Does the power supply fan start? Can you hear the hard drive spin up? If you're not sure, just tell me what happens. Also, how long has this been going on and when did it start?
Have you tried cleaning its memory? or is your video card built in? if not try cleaning it (but be very careful you might scratch its terminals) try cleaning your memory using a rubber eraser. then clean the slots with a brush...
Posted on Apr 21, 2009
What do i do when it comes on and shows analog then goes blank ?
Are you using the analog input or another? If using another input instead, then press the 2 key. It will switch to another input as the source signal. If you still experience trouble, please contact ViewSonic technical support for assistance.
May 03, 2014 | ViewSonic VG1930WM LCD Monitor
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
NO DVI INPUT SIGNAL AND MONITOR GOES TO SLEEP
you can't run 2 different inputs at the same time. VGA takes prescedence.
Apr 06, 2014 | HP L1950 Monitor
How to change input select to analog
Lacey,
We need some information about your setup and exactly what menus you are accessing to give an accurate response.
Laptop or desktop?
Which operating system ? Windows, Linux, mac ? Version numbe?
What preference dialogue window did you access ? One for video inputs settings perhaps?
- the black screen “ lag” sounds like the system trying connect to a different port but fails to find signal and reverts back
Nov 11, 2017 | Hanns.G Corporation HW191D 19" LCD Monitor
Hello i just installed my chimei 19" lcd to my hard drive and i have connected it all up right it all loads up but when my screen comes on the little button on screen goes from green to red and says no...
Most probably your monitor has two inputs, one digital and one analog. Using the monitor's on screen menu select the other input and you should see your picture.
Dec 18, 2009 | Acer AL1916W 19" LCD Monitor
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor goes black when i turn it on
just a big hardware problem in your monitor
Sep 23, 2009 | Samsung SyncMaster 216BW Monitor
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
