Question about Sony SLV-D350P DVD Player/VCR
LG V8824 Hi, I have had this dvd/video combo for a couple of years no problems. Last week all of a sudden the DVD function stopped working. You put a Movie in and it tries to read it and then gives a Disk error error and ejects the disk. I have tried numerous movies and all do the same. I opened the unit to clean the heads and when I put a disc in it says its trying to read by the disc doesnt spin. I maybe missing something but isnt the disk meant to spin fo the unit to read the Disc. I am thinking the Motor on the DVD unit is stuffed. Any ideas. BTW the video player still works. thanks ikhan42
The small 12 tooth gear on top of the slide motor could have a crack in it , this will lock the slide from working
Posted on Jan 08, 2008
SOURCE:
How do I play the second movie on a double feature dvd disc?
Hi Tia, put the disk in and when the main menu comes up select the movie you want.
Apr 03, 2018 | Televison & Video
Technika 23" dvd combo DVD just shows no signal.
I also have this problem but the DVD will not eject.
Dec 27, 2011 | Televison & Video
Disc read error
Dear Sir,
After 2-3 years generally all optical drive lenses goes bad,so first try by cleaning lences,if it not solves your problem then try by replacing lence of your DVD Drive,if you have any problem regarding this issue leave a feedback we will glad to assist you.
have a nice day
good luck
Sep 11, 2009 | Toshiba SD-P1900 Portable DVD Player
Insignia flat screen (tv/dvd) combo. dvd player does not work
Get someone technical to open the unit and clean the laser lens with a swab of eyeglass cleaner and also clean the rails that the laser runs on
Please rate my help if this helps
Thanks
Aug 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Emerson AV50 says ''NO DISK''
Hi, sounds like you have a dirty laser eye on the DVD player. The eye gets dirty and it won't read movies or function properly. I would recommend a DVD Cleaner CD. I would have you try this before I have you open the DVD Player to clean the Laser Manually. Please try this and Post the Result for me to Review. Thank you
May 19, 2009 | Emerson Audio Players & Recorders
Movie recording disabled
   Just delete unuseful data from drive or connect the camrea to your pc cut the required movie and paste it on your pc drive then it will work.
Thanks for using fixya.
Feb 15, 2009 | Sony DCR-DVD608E DVD Camcorder
Dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Aug 03, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
MY SAMSUNG DVD+VIDEO COMBO V4600
What you're describing is a common problem for this particular unit, a bad spindle motor. In some cases the motor can be removed by the tech and torn down for cleaning.. But in a high percentage of cases shops just replace the motor... What's happening, as your symptom appears the spindle motor is beginning to spin irratically. In turn the picture can sometimes just drop out. In others it simply folds over and is unwatchable. The spindle motor is not too expensive.. Good Luck Bill
Jun 10, 2007 | Samsung DVD-V4600 DVD Player/VCR
Sony SLV-D350P DVD Player/VCR Logo
228 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
