Question about Jensen LXA400 Car Audio Amplifier
Not getting power to the amp - Jensen LXA400 Car Audio Amplifier
    Problem Solver:
  • 8 Answers
Check all the connections along the wire make sure its not pinched or got a cut any where..where electricity can escape check the battery if the above didnt work autoparts does it for free that should fix the problem
Posted on Apr 21, 2009
Ematic 7" QUAD CORE TABLET EGQ307 FORGOT PASSWORD HOW TO RESET IT CANT GET ON ANYTHING WITHOUT IT
I have also take help from this helpline number 1-888-551-2881..
before sometime i have also same problem like you, i forgot my password of my Gmail account and that account contain important data,,I just call this number 1-888-551-2881..& get best solutions
related website: Gmail Password Recovery
Jan 08, 2014 | Ematic Eb104 eBook Reader
I have 2 15 inch kicker l7s duel 2 ohm in a built to specs slot port i need an amp that will power them what should i get
this guy know jl amps are ONLY 1.5 - 4 ohm stable? won`t 1 ohm send amp into protection with thermal indicator lit up like the northern star?
Sep 26, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i get my amp to push out all the power it can?
Hello
Yours' is a power amp only. For every power amps, there will be an input sensitivity measure, thet we should give them to get full power out of them. Just check the input sensitvity of your power amp. It will be designated in its user manual's specification part.
Suppose, the input sensitivity of your amp is stated as 250mv to 100W, means, you have to input a signal of 250 milliwatts to its input terminal, to get a power of 100Watts at its output. Normally, these are of theoritical values and won't never match with the actual value. Anyway, it will come very near to that. For example, if your amp is of 100Watts output with 250milliwatts of input, it may give you 85 to 90Watts of power ot 250 milliwatts of input.
I think that I'm very near to your mind. Ok.
A MERRY X'MAS AND HAPPY 2012 TO YOU ALL; WHERE EVER YOU MAY BE.
Gopakumar G, Trivandrum City, South India.
Dec 23, 2011 | Boss gt580 - GT580 1000W 2 Channel MOSFET...
My Friend put A Rockford Fosgate P250.2 Amp in his car and while hooking it up he forgot to connect the ground but still got power to the amp but no sound from the subs and the thermal light is on. so he...
Your friend has damaged his amp. The power light coming on means that the amp's power indicator LED is at least working. That light is only there to tell you that the amp is receiving power on it's 12 volt rails, not that it's necessarily using the power in any way other than warming up the amp's internal circuitry. When you say the amp gets power, I'm not clear on whether you mean the amp works in that fashion, or there's just a red LED glowing but nothing else happens. The amp needs to be repaired, and I would suggest to him to not apply power to it again until it is checked by a professional. The power supply has probably been damaged, and it's possible, depending on how the amp was mounted, that it was searching for ground through the amp's chassis if it was screwed into metal at its mounting location. All that seems certain as of now is that the LED works, but nothing else, unfortunately.
Jul 02, 2017 | Rockford Fosgate P3001 Car Audio Amplifier
I have a 1100watt sub woofers, and a 1000 watt amp. Will the my sub woofers, or amp blow out or get damaged.
Are those rms wattage?
Anyways, your subs (if you have two) will double the power of your amp, meaning your amp will be under powering your subs. Nothing will get blown out but will never see their full potential. But if you were to use single sub with your amp then you are more likely see the full potential of the sub and amp.
2 subs=2200 watts is just twice the power of the amp output power!
Jan 06, 2011 | Car Audio & Video
Laptop not starting properly
follow these steps & ur issue might get resolved(80% chances):
turn off ur notebook-->take out the laptop battery(not the cmos battery)-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved, turn off ur notebook again & restart to ensure that its not reoccuring....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 11, 2010 | Computers & Internet
Blank screen when turned on, then there are 2 lights that flash they both have a lock symbol before them one is with an A and the other is with a 1. Everything else lights up but screen is just blank/black
turn off ur notebook-->take out the battery-->disconnect the charger if its connected to the notebook-->now press & hold the power key for atleast 20 seconds, remember that u have to press & hold the power key & dont release the power key till 20 seconds are over--> & ensure that the notebook is not connected to any power source while u r performing this step niether the battery nor the charger--> also there shouldn't be any peripherals connected to the notebook-->once 20 seconds are over & u have released the power key-->connect the battery & the charger back to the notebook & now try to turn on the notebook-->u might not get a blank screen & ur issue might get resolved....(This whole step is known as power drain & it is done to remove the extra static electricity which sometimes get stored in the notebook & gives a blank screen in return.)
Jul 08, 2010 | HP EliteBook 6930p Notebook PC
Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Aug 23, 2009 | Black & Decker 100 Watt Plug-In Power To...
No power to amp
Hi do you have power back to the amp on the main feed if so check the fuse in the amp
May 17, 2009 | 2002 Chevrolet Impala
Buzz from lexicon lx-7 power amp
Might be caused by any of the Large Capacitors in the power supply section of the amp.
Nov 15, 2008 | Audio Players & Recorders
Jensen LXA400 Car Audio Amplifier Logo
78 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
