Question about Samsung DVD-L300 Portable DVD Player
Samsung l300a dvd player - no video, only audio
When I power on the player, it shows the SAMSUNG logo then goes blank, although I can hear the audio portion of the DVD.
  • 1 more comment
  • this-is-john Sep 21, 2007
    Thanks but that didn't make any difference.
    When I hit the PLAY button, it shows samsung for about 1-2 seconds then a blank screen. If I plug in the earphones I hear the DVD.
    I tried the 'reset' but it still doesn't work. When I press the play button, the Samsung screen comes on for 1-2 seconds, then no video at all, but I can hear the audio portion.
  • this-is-john Sep 22, 2007
    The "simple" act of plugging a cable into the input port freed up something because the video came back.
    Thanks for the help.
  • 752 Answers
Try hooking up an external source (like another dvd player) to the video inputs on it. If you get picture through those, then it's a problem on the mainboard.
Posted on Sep 21, 2007
    Master:
    Sergeant:
  • 461 Answers
Try to reset the player. Remove the DC power supply. Remove the battery. Leave it for 30 mins. Power on using the DC power supply without the battery.
SOURCE:
My Samsung Infuse 4G doesn't want to turn on but it keeps flashing Samsung
Forgotten the Password of the Lock Screen on Android,How to Unlock?
Android Lock Screen Removal & Data Recovery does well in removing the password of PIN, patterns, password and fingerprint on Android. And this program covers over 6000 Android phones and tablets from Samsung, HTC, LG, Sony, Motorola, ZET, Huawei, Lenovo, etc.
Even the screen turns black, you are unable to open the USB debug, forget the lock screen password, Android touch screen cannot be used or just can't enter Android system for unknown reasons. There is still a chance for you to retrieve lost or deleted contacts, sms, pictures, videos, whatsapp chat messages, calendar on locked screen Android with this software.
LEARN MORE
Broken Android Data Extraction
How to Recover Data from Broken Samsung Galaxy S9 S8 S7 S6
How to Recover Contacts from Broken Samsung Galaxy S9 S8 S7 S6
How to Recover Data from Broken Samsung Galaxy Note 9 8 7 6
How to Recover Photos from Broken Samsung Galaxy Note 9 8 7 6
Apr 21, 2013 | Samsung Infuse 4G Smartphone
How to tune up dvd player
  • Plug the power cable of the Samsung VHS/DVD player into an available power outlet near the television.
Connect a set of RCA audio and video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. The colors of these cables are yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to the color-corresponding inputs on your television. When plugging in these cables, look for a label for the input, such as "Video 1" and "Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step 3. If you did not take note, you can also tune through your television's input channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Component Video
Connect a set of component video cables to the color-coded outputs on the back of your Samsung VHS/DVD player. These cables will look similar to composite audio and video cables, but they are instead color-coded as red, blue and green.
Plug the other end of the component video cables into the color-corresponding inputs on your television. Take note of what input number you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your VHS/DVD player, then connect the other ends to your television. These cables are color-coded as red and white and must be plugged into the same input number as the component video cables.
Tune your television to the component video input channel where you connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play" button to verify that the unit is functioning properly.
Jul 10, 2012 | 2005 Toyota Caldina
I don't know which cables to use to hook up my sony plasma to a samsung dvd player, or how to hook it up.
Hi there. To enable your Samsung DVD player to work on your Sony Plasma, you will need two things:
1. The Power cable for the DVD player
2. The Audio(Red and White) and Video(Yellow) cables that should have been provided when the DVD player was bought. If ever these cables are not available, you may buy these at any Hyper Market such as Wal-Mart or a technology store such as Best Buy. These are called Composite Video and Audio Cables.
If you have the previous cables, connect the 3 Audio/Video cables to the back of the Plasma TV, it should contain the appropriate ports. Yellow cable(Video) for the Yellow port. White and Red for the Audio Left(L) and Right(R) ports. Then connect your power, turn the DVD on and switch from TV to other input which should display the Samsung Logo.
Please rate and comment, thank you.
Apr 14, 2011 | Video Game Consoles & Games
Hi there, I don't want to buy another dvd player, I would like to know how do I change the codes on a Panasonic-S54dvd player so that it can play all Regions?
This may or may not work i found it on a form and if it does not everthing other than this is a nightmare to get to work or you have to buy things
1. Remove any DVD discs from the tray/unit.
2. Switch off the DVD player and unplug the power cord.
3. Wait 30 seconds, then reconnect the power cord.
4. Turn on the DVD player with the supplied Samsung remote and wait for player to finish loading and display 'no disc' or the Samsung logo before you do anything else.
5. Press Enter on remote. (There will be no on-screen response to you doing this.)
6. Press the following numbers in sequency using the supplied Samsung remote unit's keypad -
8, 4, 2, 6, 9 (omit the commas shown here)
(Again, there will be no on-screen response to this action.)
7. Press Enter on the remote. The DVD Player will automatically shut off.
8. Now, turn the DVD player on.
9. When it is on and showing the "no disc" or Samsung logo, turn it off again.
10. Repeat this action by turning the DVD player on, then off again.
11. The DVD Player should now be Region-free.
Feb 28, 2011 | Panasonic DVD-S54 DVD Player
Connected samsung ht x720 (home cinema system 2.1) to v+ box.Cant get picture when playing a DVD.Can hear the sound tough.Thanks
You probably need to change the incoming input signal on your tv.
In other words, your audio is coming directly out from your dvd player, and going directly to the audio power amp.
Your video does the same thing, except it goes to your tv. Your tv has multiple places for "incoming" signals to hook in to it. Take a look at where you're hooking your video in - the input should be marked ... something like "Component 1" "Component 2" "HDMI 1" "HDMI 2" ... something like that.
On your remove, there will be a button that says, "Input." When you push this, you will see that your TV brings up an input selection window. Pressing the "input" button on your remote should scroll through the ports on the tv. Briefly pause on each input selection to see if it begins receiving a video signal from your DVD player.
Nov 19, 2010 | Samsung Audio Players & Recorders
Unlock region free?
6. Press the following numbers in sequence using the supplied Samsung remote unit's keypad -
8 4 2 6 9
Sep 29, 2010 | Panasonic DVD-S54 DVD Player
I am trying to record to a blank dvd-r. I load a
If exact model is Samsung DVD-VR357, than it doesn't even has to recognise blank disc as your unit is DVD PLAYER with Video Casette Recorder.
See Specs. for your unit below:
Function Combination VCR Y Compatibility Playback Media DVD-R,DVD-RW,DVD+R,DVD+RW,CD-R/RW,CD,VHS, DVD-RAM Playback Formats MP3, WMA, JPEG, MPEG-4, DivX A/V Quality Progressive Scan Y HD Upconversion 720p/1080i Digital-to-Analog Converter 10-Bit/54MHz DTS Output Y Dolby Digital Surround Sound Y Connectivity HDMI CEC Y Convenience Child Protection Parental Control Physical Features Connectivity HDMI Output Y Component Video Output 1(Rear) S-Video Output 1(Rear) Composite Video Output 1(Rear) Coaxial Digital Audio Outputs 1(Rear) Optical Audio Output 1(Rear) Product Weight & Dimensions Dimension 16.9" x 3.1" x 11" Weight 8.8Lbs. Shipment Weight & Dimensions Dimension 20.2" x 7.1" x 15.1" Weight 12.1Lbs.
Closest model match for DVD recording unit would be DVD-VR375
Unfortunately you have player only and you won't be able to recor DVDs with it whatsoever.
Good luck
Jun 24, 2009 | Samsung DVD-VR357
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
Samsung portable dvd player
those kinda players wont play DVD rom disks and certain ones that are made up. DVD-RAM or ROM wont work. Try blowing inside the player for any dust. if it still doesnt work its the maufacters problem. The player will play CD-G audio only, not graphics The ability to play back DVD-R, DVD-RW, DVD+R, DVD+RW, CD-R, CD-RW, and CD-Jpeg discs may depend on recording conditions.
Jun 25, 2006 | Verbatim (94562) Media
Samsung DVD-L300 Portable DVD Player Logo
223 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
