Question about Epson Office Equipment & Supplies
Service required for epson stylus t10 - Epson Office Equipment & Supplies
  • Art Ellison
    Art Ellison May 11, 2010
    What kind of service?
Printer epson t10 error service required Problem
Posted on Feb 01, 2010
5 Suggested Answers
  • 3 Answers
SOURCE: my printer epson stylus T10
you can also use the SSC service utility
Posted on Mar 22, 2009
  • 5603 Answers
SOURCE: My Epson Stylus T10 Printer have a problem...it
The waste ink pad needs to be replaced or cleaned AND the service software used to reset the internal counter. You cn download tthis online.
You have to dis-assemble the printer to get at the pad. You can clean the pad with agressive rinsing till it is a very light gray color. (A lot of ink will be flushed out!)
Posted on Oct 23, 2009
exil0r
  • 118 Answers
SOURCE: service required
Ink absorber is full. I know software to reset c90, the type is similar as t10, you can find the reseter code here and hopefully can reset t10 or reseter for this type have released.
Posted on Apr 14, 2009
cns assoc
  • 677 Answers
SOURCE: epson stylus T10 printer stopped working
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Posted on Mar 19, 2010
Installer epson stylus T10
You can download the Epson printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Mar 29, 2013 | Epson Stylus T10
Please help me on how to reset my epson stylus t10.. thank you
The Stylus T10 is an inkjet printer developed by Epson known for its affordable printing. When you replace one or all of its cartridge with fresh one(s), you will need to reset the printer to get a correct ink level reading. You will require a resetter program for T10 to perform this task. The program is designed for this printer and other printers belonging to the same series. Note that you may need administrative rights to install the resetter program on the computer to which your Epson printer is connected to.
1.
Download the "Epson Adjustment Program" (resetter program for T10). See Resources to download the .RAR file.
2.
Double-click to extract the contents of the .RAR file once you have finished downloading it. The exact file is "ReseterforEpsonT10_T11.rar."
3.
Turn on your Epson Stylus T10 printer. Make sure it is connected to one of the open USB ports on your computer.
4. Double-click "Loader.exe" from the list of files extracted in Step 2. 5. Click "Accept" after reading the "License Agreement." 6. Click "Select" to select your printer model. In this case, choose "Epson Stylus T10." 7. Choose "Auto detection" on "Port" menu. 8. Click "Particular Adjustment Mode." 9. Click "Maintenance" and choose "Waste Ink Pad Counter."10. Click "Check" to display the counter. Hit the "Initialization" button. Wait until the counter initializes.
11.
Turn off the Epson Stylus printer when prompted. Hit "OK."
12.
Turn on your Epson printer when prompted. Hit "OK."
13.
Click "Check" to make sure your have finished the reset.
14.
Close the program to end the task.
Aug 11, 2011 | Office Equipment & Supplies
Does epson T10 printer does not work with windows 7?
EPSON STYLUS T10 Printer -> Compatible with Win 7.
You can check harware Compatibility @ Windows 7 Compatibility Center
EPSON STYLUS T10 Printer - This product installs automatically without extra software on Win 7.
Drivers & Support: Epson Stylus T10
Hope it helps.
Nov 12, 2010 | Computers & Internet
Free printer installer for epson Stylus T10
how can i install my epson stylus t10 printer if I lost my installer
Aug 16, 2010 | Epson Office Equipment & Supplies
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
1,752 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
