Question about Troy-Bilt Pony Garden Tiller
Mower will only run if choke is on
Briggs 17.5 troy bilt mower will cut off if taken choke off and when blades are engaged
  • 246 Answers
Hello cmsbss:
>>From your Description it Sounds like the Carburetor requires Soaking and Cleaning.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy bilt lawn mower
sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Jul 13, 2013 | Garden
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Sep 07, 2009 | Garden
I have a troy pony 17.5 that cuts off when you engage the blade and the choke is on. what can i do to fix the problem. thank you for any help to fix this problem
does it run ok off choke with blade not engaged can you rev it up ? if not it sounds like the carbs got issues ? if it does check the second wire coming off the igntion coil too the safety switch may be grounding /shorting causing engine to shut off kinda like the handle on your push mower when you walk away and let go of the handle the zone control cable stops the spark and flywheel ? carb rebuilds at your local shop are under $100 well worth it unless youve done it before kit costs like $15
Aug 25, 2009 | Troy-Bilt Pony Garden Tiller
Mower runs but blades aren't turning
You can get help at both of these places:
http://troybilt.custhelp.com/cgi-bin/troybilt.cfg/php/enduser/std_alp.php
http://www.mowersdirect.com/technical-support.php
Aug 03, 2009 | Troy Garden
Troy-Bilt Pony Garden Tiller Logo
2,670 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
